Use of Tu for user expression
Old   August 7, 2006, 07:55
Default Use of Tu for user expression
Adam
Has anyone successfully used the turbulence intenstity (Tu) in a user expression or subroutine?
Even though it is a user input option it doesn't seem possible for the user to utilise it in any expression or routine.
Regards
Adam
Old   August 8, 2006, 03:21
Default Re: Use of Tu for user expression
James Date
Why don't you set it as a constant in the CEL expression language and then you can use it anywhere, even to set Tu on the inlet boundary. You could set up the following CEL expressions, which will allow you to calculate Tu and Epsilon:
UsrFlowSpeed = 10 [m s^-1]
UsrChord = 1.0 [m]
UsrDynamicViscosity = 0.0016 [kg m^-1 s^-1]
UsrDensity = 1028 [kg m^-3]
UsrTurbIntensity = 0.003
UsrInletK = 3.0*((UsrTurbIntensity^2)*UsrFlowSpeed^2)/2.0
UsrInletEpsilon = 0.085*UsrDensity*UsrInletK^2/ 10*UsrDynamicViscosity)
I hope this is useful.
James
Problem About Running Fluent In Linux mitra FLUENT 18 June 20, 2019 02:11
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Lift, Drag Vs time chart,calculations Jamesd69climber CFX 8 February 17, 2005 17:23
Creating, loop or iteration using expression edito Jan CFX 3 July 28, 2003 11:01
