Mesh deformation
Old   July 10, 2006, 11:33
Default Mesh deformation
Elian81
Hi to everyone I'm an Italian student and i have to study a gear pump, for this study i want to use the mesh deformation, i had do the tutorial 20 but when i start cfx solver for my geometry it tells that can't read the file mesh .0 in the working directory. How can i create this kind of file? i have to use patran neutral mesh or i can use a mesh create with cfx pre mesh? Help me please.. Sorry for my bad English
Old   July 10, 2006, 11:35
Default Re: Mesh deformation
Joe
Copy the mesh files from the totorial subdirectory in your CFX installation. This is clearly explained in the manual.
Old   July 11, 2006, 02:13
Elian81
ok the tutorial run ok but whow can i do the file of mesh with the extension .0 .1 for my gear pump mesh??and i have to use a patran file for doing a mesh deformation?
Old   August 9, 2006, 07:04
Venkat
I am also having the same doubt. How can I create series of meshes, which will be used for MESH MAPPING. I heard that FORTRAN code is required to do so. But I am not sure.
Thanks in advance.
Old   September 1, 2006, 08:19
Tim
Me too. If any one have experience of mesh defromation in CFX, please share with us. I can do that easily in Fluent, for CFX, a lot of trouble. It do need Fortran code.
Old   September 6, 2006, 06:57
popi
I'm also working on that. I'm using CFX 10 and as I know you can do a mesh deformation doing a mesh map using the junction box routine. But you need the FORTRAN to make the subroutine and read the meshes, and also to compile the subroutine that will be called by the junction box. This is the only thing I know.I'm trying to do a simulation of an Internal Combustion Engine. I know how it could be but i'm not able to make the subroutine which read the meshes. Please, if anyone knows something about this....tell me
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Timestep with mesh deformation rbarrett CFX 4 July 21, 2011 19:25
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
