CFX load Results file
Old   August 22, 2006, 06:02
Default CFX load Results file
furkan
hello everybody
I solved a simulation using CFX10.0 step by step (almost every 2000 number of time was solved) now I am taking the result from CFX Post procesesor.but last time step number is 60000. is there any way to load all results files in one cfx-Post. otherwise i have to open 30 cfx results files to collect the results....I tried to load using Ctrl+Mouse, but it does not work....
regards
Furkan
Old   August 22, 2006, 07:22
Default Re: CFX load Results file
longbow
CFX-11 allows you to open multi-file. But I daunt you can open such large number of files altogether even with CFX-11. One solution to your problem is to let CFX-Post automatically load those 30 results and do postprocessing on each result one-by-one. What you need to do is to record all the operation you would like to do for one result and then replay session or state file.
Old   August 24, 2006, 07:18
furkan
thank you longbow... I got it. but non-multi-file option in CFX10.0 is a big problem...
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
