-   -   MPICH Parallel Run Error on the Windows Server2003 (http://www.cfd-online.com/Forums/cfx/22975-mpich-parallel-run-error-windows-server2003.html)
Saturn August 22, 2006 22:22
I run the MPICH Parallel on the Windows Server 2003 Dual CPU machine cluster. I can use the MPICH Local Parallel for Windows mode and got the converge results. When I used the MPICH Distributed Parallel for Windows mode to run parallel cases, it showed the Solver Terminated error as following.
An error has occurred in cfx5solve:
The ANSYS CFX solver has terminated without writing a results file. Command on host cluster exited with return code 0.
I have checked the RSH service and the RSH can return value.
How should I resolve this error in ANSYS CFX solver for MPICH parallel?
Thanks a lot.
Bian August 24, 2006 08:35
Re: MPICH Parallel Run Error on the Windows Server
Are you sure your MPICH Deamon is running with correct user registered?
Saturn August 24, 2006 10:11
Hi, Bian
How do I check the correct user registered for my MPICH Deamon?
I registerd the user that same account in RSH service.
Thanks a lot.
Bian August 29, 2006 08:42
If you followed the setting up instruction, you would see MPICH service in running services (right click on "my computer", click "manage", select "services")
One more thing, turn the Windows firewall off. Otherwise, the distributed parallel might not run.
