PARTICLE TRACKING
Old   August 23, 2006, 04:57
Default PARTICLE TRACKING
vipin
SIR,
IN PARTICLE TRACKING, IS IT POSSIBLE THAT IF THE PARTICLE STRIKE THE WALL IT IS SETTLE DOWN IN THE DOMAIN? HOW?
IS IT POSSIBLE TO CALCULATE THIEIR NUMBERS?
THANS FOR CO-OPERATION
VIPIN
Old   August 23, 2006, 06:56
Default Re: PARTICLE TRACKING
Felix
Hello Vipin,
it is possible to remove a particle when it hits a wall. You need to change the values of the restitution coefficients to zero. You can find them within the boundary condition for the wall -> "Fluid Values" -> "Velocity" -> perpendicular/parallel coefficient. In CFX-Post you can calculate the mass flux of particles through the wall. But the output-file gives you the number of particles which where collected on the wall. I don't know if there is a possibility in CFX-Post to get the particle number of collected particles on the wall.
Regards, Felix
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 00:59
massless particle tracking problem Renold FLUENT 0 January 26, 2011 14:23
Particle Tracking for ion Jun CFX 2 August 31, 2010 08:19
Number density tracking rather than particle tracking Rebecca Main CFD Forum 2 April 23, 2009 12:52
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
