Gambit to CFX
I used Gambit to generate a .msh mesh. I read it in FLUENT and exported it to a CGNS file. When I read it in CFX-pre, I am not getting all of my regions. I have no boundaries. I have just one Fluid region. Therefore I am not able to specify any boundary conditions. Can anyone help?
Re: Gambit to CFX
Write the mesh as .msh, read it in tgrid, export as patran neutral file and then read, it in cfx, you will have all boundary regions.
Re: Gambit to CFX
thanx a heap,Zxaar. I am going to try that right away.
Re: Gambit to CFX
Is there a way possible to do this without Tgrid? I don't have Tgrid, and after going around talking to some people i know, i realised that no one else has it either.
Thanking in anticipation |
Re: Gambit to CFX
Well I only worked with CFX one day, (last friday, So all my CFX experience is just one day), so I am still thinking of a way of doing it without tgrid. But if you do not have tgrid, download it from fluentusers.com and install it, it shall work with the same license.
Re: Gambit to CFX
Thanks a lot Zxaar for your co-operation. I finally was able to do it without Tgrid. I can read the .msh from Gambit to FLUENT. Then I need to initialise it. Then save it a PATRAN neutral file. Directly readable with all regions in CFX. Talk about coincidence, I am new to FLUENT as you are to CFX
Re: Gambit to CFX
Yepp Patran neutral is the format requred for it. I did not explore the Fluent solver to export to partan, the simple reason was we have one month demo license and I had to do lot of calculations. So first day I was supposed to learn CFX and start the calculations. (SO I did)
Re: Gambit to CFX
Why not use ICEM for it? If someone have CFX then, in most cases, ICEM CFD is also purchased...
Re: Gambit to CFX
Thanks you guys, zxaar and deLuther.
Re: Gambit to CFX
Hi Omer, Zxaar,
Do you know whether you could create an axisymmetric model for cfx using gambit? NH |
