August 26, 2006, 03:27 |
Gambit to CFX
I used Gambit to generate a .msh mesh. I read it in FLUENT and exported it to a CGNS file. When I read it in CFX-pre, I am not getting all of my regions. I have no boundaries. I have just one Fluid region. Therefore I am not able to specify any boundary conditions. Can anyone help?
August 27, 2006, 03:47 |
Re: Gambit to CFX
Write the mesh as .msh, read it in tgrid, export as patran neutral file and then read, it in cfx, you will have all boundary regions.
August 27, 2006, 03:57 |
Re: Gambit to CFX
thanx a heap,Zxaar. I am going to try that right away.
August 27, 2006, 04:04 |
Re: Gambit to CFX
Is there a way possible to do this without Tgrid? I don't have Tgrid, and after going around talking to some people i know, i realised that no one else has it either.
Thanking in anticipation |
August 27, 2006, 05:11 |
Re: Gambit to CFX
Well I only worked with CFX one day, (last friday, So all my CFX experience is just one day), so I am still thinking of a way of doing it without tgrid. But if you do not have tgrid, download it from fluentusers.com and install it, it shall work with the same license.
August 28, 2006, 05:14 |
Re: Gambit to CFX
Thanks a lot Zxaar for your co-operation. I finally was able to do it without Tgrid. I can read the .msh from Gambit to FLUENT. Then I need to initialise it. Then save it a PATRAN neutral file. Directly readable with all regions in CFX. Talk about coincidence, I am new to FLUENT as you are to CFX
August 28, 2006, 05:39 |
Re: Gambit to CFX
Yepp Patran neutral is the format requred for it. I did not explore the Fluent solver to export to partan, the simple reason was we have one month demo license and I had to do lot of calculations. So first day I was supposed to learn CFX and start the calculations. (SO I did)
August 28, 2006, 10:22 |
Re: Gambit to CFX
Why not use ICEM for it? If someone have CFX then, in most cases, ICEM CFD is also purchased...
August 30, 2006, 11:04 |
Re: Gambit to CFX
Thanks you guys, zxaar and deLuther.
September 23, 2006, 20:05 |
Re: Gambit to CFX
Hi Omer, Zxaar,
Do you know whether you could create an axisymmetric model for cfx using gambit? NH |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
gambit mesh to cfx | Hossam | CFX | 1 | November 9, 2008 11:39 |
Importing Gambit files into CFX | CF | CFX | 8 | September 25, 2006 02:14 |
CFX 10's solutions differ from CFX 5.7's | Atit Koonsrisuk | CFX | 4 | July 26, 2006 11:59 |
import gambit .neu directly to CFX? | jemteo | CFX | 2 | June 6, 2006 15:00 |
