MPICH Parallel Run Error on the Windows Server2003 |
August 22, 2006, 22:22 |
I run the MPICH Parallel on the Windows Server 2003 Dual CPU machine cluster. I can use the MPICH Local Parallel for Windows mode and got the converge results. When I used the MPICH Distributed Parallel for Windows mode to run parallel cases, it showed the Solver Terminated error as following. -------------- An error has occurred in cfx5solve: The ANSYS CFX solver has terminated without writing a results file. Command on host cluster exited with return code 0. -------------- I have checked the RSH service and the RSH can return value. How should I resolve this error in ANSYS CFX solver for MPICH parallel? Thanks a lot. |
August 24, 2006, 08:35 |
Re: MPICH Parallel Run Error on the Windows Server
Are you sure your MPICH Deamon is running with correct user registered?
August 24, 2006, 10:11 |
Hi, Bian
How do I check the correct user registered for my MPICH Deamon? I registerd the user that same account in RSH service. Thanks a lot. |
August 29, 2006, 08:42 |
If you followed the setting up instruction, you would see MPICH service in running services (right click on "my computer", click "manage", select "services")
One more thing, turn the Windows firewall off. Otherwise, the distributed parallel might not run. |
stop when I run in parallel | Nolwenn | OpenFOAM | 36 | March 21, 2021 04:56 |
SimpleFoam run in Parallel | jayrup | OpenFOAM | 9 | July 26, 2019 00:00 |
Script to Run Parallel Jobs in Rocks Cluster | asaha | OpenFOAM Running, Solving & CFD | 12 | July 4, 2012 22:51 |
problem in parallel run in Workbench | Mina_Shahi | CFX | 0 | September 8, 2011 11:27 |
Parallel run in fluent for multiphase flow | apurv | FLUENT | 2 | August 3, 2011 19:44 |
