why ICEM come out unreasonably?
Old   September 1, 2006, 21:48
Default why ICEM come out unreasonably?
prayskyer
Recently, i pick a complex geometry to mesh using ICEM with texth(unstructure mesh),when it come up to 28%,it come out sudently,. when it can happen,somebody help me.
Old   September 2, 2006, 14:11
Default Re: why ICEM come out unreasonably?
Chebeba
I'm afraid not
ICEM is not a very stable software, there are lots of things that can make it crash. Everytime I start a new model I encounter new bugs...
Anyway: Always check that your geometry is clean to start with. Then check that you can do a surface mesh. If not get that working and go from there.
And call talk to your support rep when all else fails.
/C
Old   September 12, 2006, 10:20
Fusion
There is a limit on cells number based on the available RAM; when ICEM create an unstructured mesh, it meshes beyond the domain boundaries, then it cuts and refines the mesh; during this operation you can have a millions cells mesh, resulting in a "insufficient RAM" error (this is true for tetra, I don't know if your case is the same).
Try to divide your domain in more than one body, than mesh the bodies separately, or try to divide your geometry in more than one file, than mesh each part and merge them.
Good luck. F
PEM Fuel cell module meshes. ICEM vs workbench aarvay FLUENT 24 March 2, 2020 06:50
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes rooftop ANSYS Meshing & Geometry 19 March 31, 2016 02:33
[ICEM] complex 2D meshing on ICEM kassab ANSYS Meshing & Geometry 26 April 14, 2014 21:02
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
ICEM CFD 5.1 Hex-Tet mesh merging failure bogesz CFX 1 January 29, 2005 06:46
