-   -   about compresive phase (http://www.cfd-online.com/Forums/cfx/23037-about-compresive-phase.html)
James September 8, 2006 02:39
when I model the multiphase of water and air,as I need to set the pressure at the inlet,such error come out:
Notice This is a multiphase simulation with a compressible phase. Total pressure (used for post-processing or if total pressure is specified at a boundary) is calculated assuming all phases are incompressible.
What should I do to deal with it,if I insist to set the pressure of inlet ?any suggestion will be appreciated.
Joe September 8, 2006 06:11
Re: about compresive phase
Its unlikely that you should be setting the gaseous phase as compresible in the first place.
Robin September 8, 2006 07:47
How do you figure that Joe?
Joe September 8, 2006 12:43
A typical tank sloshing flow is hardly going to result in signifciant compression effects in the gaeous phase ...
Robin September 8, 2006 14:07
...if you are simulating tank sloshing. James said nothing of the sort.
Joe September 8, 2006 15:14
To be precise, he didnt bother to specify his problem at all. An all to common occurance here. Hence my question ...
Joe September 8, 2006 15:17
Correction, he did mention it was a tank sloshing problem: http://www.cfd-online.com/Forum/cfx.cgi?read=16846
I'll posed questions spread over multiple posts ... and people wonder why they dont get proper answers to their questions.
James September 8, 2006 20:05
Hi,Joe and Robin,
my model is compressible fluid as it is vacuum in the domain and with pressure at the inlet boundry condition.
Robin September 11, 2006 09:14
Hi James,
All the message is doing is warning you that the post-processed value of Total Pressure is not calculated in the same manner as it would normally be for a compressible fluid. Just keep this in mind if you are interested in Total Pressure.
Now, having a vacuum may present other problems. You can't actually specify zero absolute pressure or the code will blow. If you have water coming into the domain, a low pressure (say 0.1 atmosphere) will probably do.
Let us know how it works out.
Regards, Robin
James September 11, 2006 21:00
Hi,Robin In fact I simulate this to show the configuration of the flow in the counter Gravity filling.At first,I set the inlet using constant velocity of water.In order to close the reality,then the pressure of inlet will be included.The pressure is a constant ,but maybe because of the compressive fluid in the domain,it always goes wrong. I also set the inlet pressure as 10kpa or 30kpa,but it doesn't work ,either.Expect for your suggestion.Thanks.
James September 12, 2006 03:16
I try to simulate my model by using the degassing mdel,set the air to dispersed fluid,and set the outlet the degssing boundry,and use the free surface to simulate it.By doing this air can flow out the doman,not the water,which is I expected.Is it feasible? It converges well,but in the post I cannot get the isoface of the volume fraction,for example,water volume fraction 0.5 .The pressure works well however.can you give me some help?My setting is : LIBRARY:
MATERIAL: Air at 25 C
Material Description = Air at 25 C and 1 atm (dry)
Material Group = Air Data, Constant Property Gases
Option = Pure Substance
Thermodynamic State = Gas
PROPERTIES:
Option = General Material
Thermal Expansivity = 0.003356 [K^-1]
ABSORPTION COEFFICIENT:
Absorption Coefficient = 0.01 [m^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Density = 1.185 [kg m^-3]
Molar Mass = 28.96 [kg kmol^-1]
Option = Value
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
SPECIFIC HEAT CAPACITY:
Option = Value
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 0. [J/kg]
Reference Specific Entropy = 0. [J/kg/K]
Reference Temperature = 25 [C]
Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 2.61E-02 [W m^-1 K^-1]
END
END
END
MATERIAL: Water
Material Description = Water (liquid)
Material Group = Water Data, Constant Property Liquids
Thermodynamic State = Liquid
PROPERTIES:
Thermal Expansivity = 2.57E-04 [K^-1]
Absorption Coefficient = 1.0 [m^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Density = 997.0 [kg m^-3]
Molar Mass = 18.02 [kg kmol^-1]
Option = Value
END
REFRACTIVE INDEX:
Option = Value
END
Option = Value
END
Option = Value
Reference Specific Enthalpy = 0.0 [J/kg]
Reference Specific Entropy = 0.0 [J/kg/K]
Specific Heat Capacity = 4181.7 [J kg^-1 K^-1]
END
Option = Value
Thermal Conductivity = 0.6069 [W m^-1 K^-1]
END
END
END END EXECUTION CONTROL:
PARALLEL HOST LIBRARY:
HOST DEFINITION: yuhuan
Installation Root = C:\Program Files\Ansys Inc\CFX\CFX-%v
Host Architecture String = intel_p4.sse2_winnt5.1
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Independent Partitioning
Runtime Priority = Standard
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
END
END
RUN DEFINITION:
Definition File = D:/board02/board.def
Interpolate Initial Values = Off
Run Mode = Full
END
SOLVER STEP CONTROL:
EXECUTABLE SELECTION:
Double Precision = Off
END
MEMORY CONTROL:
END
PARALLEL ENVIRONMENT:
Number of Processes = 1
Start Method = Serial
END
END END FLOW:
DOMAIN: Domain 1
Coord Frame = Coord 0
Domain Type = Fluid
Fluids List = Air at 25 C,Water
Location = Assembly
BOUNDARY: inlet
Boundary Type = INLET
Location = INLET
BOUNDARY CONDITIONS:
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Fluid Velocity
END
TURBULENCE:
Option = Medium Intensity and Eddy Viscosity Ratio
END
END
FLUID: Air at 25 C
VELOCITY:
Normal Speed = 0 [m s^-1]
Option = Normal Speed
END
VOLUME FRACTION:
Option = Value
Volume Fraction = 0
END
END
END
FLUID: Water
VELOCITY:
Normal Speed = 1 [m s^-1]
END
VOLUME FRACTION:
Option = Value
Volume Fraction = 1
END
END
END
END
BOUNDARY: outlet
Boundary Type = OUTLET
Location = TOP
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Degassing Condition
END
END
END
BOUNDARY: wall
Boundary Type = WALL
Location = BOTTOM,SIDE
WALL INFLUENCE ON FLOW:
Option = No Slip
END
WALL ROUGHNESS:
Option = Smooth Wall
END
END
WALL CONTACT MODEL:
Option = Use Volume Fraction
END
END
BOUNDARY: symmtry
Boundary Type = SYMMETRY
Location = BACK,FRONT
END
DOMAIN MODELS:
BUOYANCY MODEL:
Buoyancy Reference Density = 997 [kg m^-3]
Gravity X Component = 0 [m s^-2]
Gravity Y Component = 0 [m s^-2]
Gravity Z Component = -9.81 [m s^-2]
Option = Buoyant
BUOYANCY REFERENCE LOCATION:
Option = Automatic
END
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
Reference Pressure = 10 [kPa]
END
END
FLUID: Air at 25 C
FLUID MODELS:
FLUID BUOYANCY MODEL:
Option = Density Difference
END
MORPHOLOGY:
Mean Diameter = 1 [mm]
Option = Dispersed Fluid
END
END
END
FLUID: Water
FLUID MODELS:
END
MORPHOLOGY:
Option = Continuous Fluid
END
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Homogeneous Model = False
Option = None
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Homogeneous Model = On
Option = k epsilon
BUOYANCY TURBULENCE:
Option = None
END
END
TURBULENT WALL FUNCTIONS:
Option = Scalable
END
END
FLUID PAIR: Air at 25 C | Water
Surface Tension Coefficient = 0.073 [N m^-1]
INTERPHASE TRANSFER MODEL:
Option = Particle Model
END
MASS TRANSFER:
Option = None
END
MOMENTUM TRANSFER:
DRAG FORCE:
Option = Grace
Volume Fraction Correction Exponent = 4
END
LIFT FORCE:
Option = None
END
TURBULENT DISPERSION FORCE:
Option = Lopez de Bertodano
Turbulent Dispersion Coefficient = 0.1
END
VIRTUAL MASS FORCE:
Option = None
END
WALL LUBRICATION FORCE:
Option = None
END
END
SURFACE TENSION MODEL:
Option = None
END
TURBULENCE TRANSFER:
ENHANCED TURBULENCE PRODUCTION MODEL:
Option = Sato Enhanced Eddy Viscosity
END
END
END
MULTIPHASE MODELS:
Homogeneous Model = Off
FREE SURFACE MODEL:
Option = Standard
END
END
END
INITIALISATION:
Option = Automatic
FLUID: Air at 25 C
INITIAL CONDITIONS:
Velocity Type = Cartesian
CARTESIAN VELOCITY COMPONENTS:
Option = Automatic with Value
U = 0 [m s^-1]
V = 0 [m s^-1]
W = 1 [m s^-1]
END
VOLUME FRACTION:
Option = Automatic
END
END
END
FLUID: Water
INITIAL CONDITIONS:
U = 0 [m s^-1]
V = 0 [m s^-1]
W = 1 [m s^-1]
END
VOLUME FRACTION:
Volume Fraction = 1
END
END
END
INITIAL CONDITIONS:
EPSILON:
END
K:
END
STATIC PRESSURE:
Relative Pressure = 0 [Pa]
END
END
END
OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
Output Boundary Flows = All
END
TRANSIENT RESULTS: Transient Results 1
Include Mesh = No
Option = Selected Variables
Output Variables List = Absolute Pressure,Air at 25 C.Volume \
Fraction,Pressure,Water.Velocity,Water.Volume Fraction
Time Interval = 0.02 [s]
END
END
SIMULATION TYPE:
Option = Transient
INITIAL TIME:
Time = 0 [s]
END
TIME DURATION:
Option = Total Time
Total Time = 1 [s]
END
TIME STEPS:
Option = Timesteps
Timesteps = 0.01 [s]
END
END
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
SOLVER CONTROL:
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Maximum Number of Coefficient Loops = 10
Timescale Control = Coefficient Loops
END
CONVERGENCE CRITERIA:
Residual Target = 1.E-4
Residual Type = RMS
END
TRANSIENT SCHEME:
Option = Second Order Backward Euler
END
END END COMMAND FILE:
Version = 10.0
Results Version = 10.0 END
Thank you.
