Microfluidics
Has CFX got microfluidics functionality ?
Also what is the price of the code for university use? |
Re: Microfluidics
Yes, its called laminar flow. |
Hi everoyne microfluidic problem
I am runing a microfluidic problem, using a small timestep in a transient simulation. I try the timestep adaptation to have a small numbers of iterations and to have a low courant number about 1, but I expect to have accumulations of one of the fluids, should I set on the conservation target? the courant nuber is about 20 :(. but with smaller timestep i can obtain around 1 the adaptation dont do nothig becouse i have 1 iteration by loop with the conservation targuet off
Thaks a lot |
Why are you using Courant number time step adaptation? Generally it is best to adapt to 3-5 coeff loops per iteration.
I do not understand what you are asking. |
I will try to adapt coeff loop per iteration to see what happen thaks a lot |
