September 19, 2006, 00:57 |
why this ERROR happen??
ERROR #001100279 has occurred in subroutine ErrAction. Message:
*** Run-time memory allocation error *** Not enough free memory is currently available on the s ystem. Could not allocate requested memory - exiting! what this error mean ? why that happen? thanks a lot~! |
September 19, 2006, 01:08 |
Re: why this ERROR happen??
I'm not sure but I guess the memories located by CFX are not enough for your simulation. Try to change the settings in CFX-Solver Manager/file/define run/ check the <show advanced controls>, change the <memory allocation fact> as <1.2x> or larger. Maybe it works.
September 19, 2006, 01:14 |
I'm not sure but I guess the memories located by CFX are not enough for your simulation. Try to change the settings in CFX-Solver Manager/file/define run/ check the (show anvanced controls), change the (memory allocation fact)as <1.2x> or larger. Maybe it works.
September 19, 2006, 01:58 |
i am sorry for that "check the , change the as <1.2x> or larger.",what's your mean about this,thanks in advance.
----------from the define run tab,i find three tabs,in solver tab,I can modify that memory allocation fact,but i modify to the most,error still~! is that what your mean? |
September 19, 2006, 02:02 |
maybe the number of mesh is too many so that exceed the upmost of CFX.
can i use parallel to solve this problem? thanks a lot~! |
September 19, 2006, 02:46 |
I believe that ur machine is not having enough memory to run the problem. The gen yard stick is u need at least 1GB ram for running a 1/4 mil nodes with combustion. If it is Non reactive flow the it will be less.
September 19, 2006, 04:36 |
Yes, that's my meaning. As my experiences, 0.5M hexa grids need 1GB memories, how about your case? if your RAM is enough, I don't know the reason for that error.
Display Modes | |
