Importing Gambit files into CFX
Old   August 18, 2006, 03:27
Default Importing Gambit files into CFX
CF
Hi!
I made a hybrid mesh with Gambit. Solving the case with Fluent didn't work, so I'm trying to solve it with CFX instead. I don't want to generate the mesh all over again. Can I somehow import the Gambit file into CFX?
Old   August 18, 2006, 04:29
Default Re: Importing Gambit files into CFX
deLuther
It can be done by using ICEM CFD, at least. (if you have fluent .msh file or case)
Old   August 21, 2006, 00:19
CF
Hi!
Thank you very much. It did work using ICEMCFD. I don't know why I didn't think of that before!
Old   August 21, 2006, 00:57
Saturn
You can export ANSYS format from GAMBIT.
BR, saturn
Old   August 21, 2006, 03:39
Michael B
http://www.cfd-online.com/Forum/cfx_...cgi?read=13315
Old   August 21, 2006, 09:13
Robin
Hi CF,
The easiest way is to export the mesh in CGNS format from Fluent. This can be read directly into CFX-Pre, including regions. You'll need to redefine your physics, however.
Regards, Robin
Old   August 28, 2006, 05:47
Omer
Works really well,if you open .msh file in FlUENT. Initialise it, and export it as Patran Neutral. Now read in CFX
Old   September 23, 2006, 17:59
NH
Hello Michael, How do I generate axisymmetric geometry for CFX?
NH
Old   September 25, 2006, 02:14
Michael B
that's worse. Since CFX is a 3D code, you have to have one layer of thickness in the 3rd direction, and then applied symmetry conditions on these sides. I think there is a CFX tutorial convering that.
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Importing IGES files into GAMBIT and meshing kartik FLUENT 3 September 23, 2008 00:12
Problem importing iges file to Gambit Tassos FLUENT 0 May 7, 2008 04:28
Converting ANSYS CFX files to Fluent files Martin S. Rasmussen FLUENT 3 January 30, 2007 15:08
Importing mesh files from Ansys into Gambit Srinivas FLUENT 2 August 6, 2002 10:02
