Home > Forums > CFX
Lift Coefficent - Advanced Model Control
Old   September 21, 2006, 04:02
Default Lift Coefficent - Advanced Model Control
Alex
hey
I have a subsonic flow over a airfoil. My CL does not decrease by a high angle of attack. My Y+<2. Where can I set the crictical Re or where can I set a point for the flow to start changing from laminar to turbulent? In Turbulence Model - Advanced Model Control I can change many Coefficient (e.g. A1, k, BC, Beta Star, C) is there somewhere a help for these Coefficient, where I can see which Size and what happens when I change one. What else can I do? Thanks a lot for your help. Alex
Old   September 21, 2006, 05:27
Default Re: Lift Coefficent - Advanced Model Control
Joe
Search the help file for the turbulence transition model.
Old   September 25, 2006, 09:25
Alex
thanks for the help. I decided to use the Gamma Model. the default value for the Transition Onset Reynold is 260. How do I calculate this value? I found:
Re_theta_c= 803,73*(Tu+0,6067)^-1,027*F(lamda,K)
F(lamda,k)= 1-(lamda*....)*e^Tu
Is this correct? How do I calculate Lamda(Pressure gradient parameter)?
Is it possible to calulate a critical Renoldsnumber via Re=x*u/v and enter this.
Thanks again
Thread Tools
Trackbacks are On
Lift coefficient in Eulerian multiphase model hennas FLUENT 1 July 4, 2011 16:50
Swirl Control - Injector Model varunrajendra FLUENT 0 September 16, 2009 09:06
Get the lift force in Eulerian multiphase model Summer FLUENT 0 July 29, 2008 11:27
Lift coefficients for Eulerian Multiphase Model Anastasios Georgoulas FLUENT 0 July 14, 2008 06:13
DPM model w/ Wave model - errors in documentation HS FLUENT 0 April 12, 2006 04:37
