Considering Gravity effect(or Hydradynamic) in CFX |
September 20, 2006, 05:22 |
Now one question about gravity effect comes to me. i'd like to simulate a channel flow in cfx considering the effect of gravity. The fluid material is constant density water. How can i simulate it? In my testing, the option of buoyancy is not usefull for constant density. How should i do? any suggestion from you?
September 20, 2006, 05:55 |
Re: Considering Gravity effect(or Hydradynamic) in
Two phase homogenous model.
September 20, 2006, 09:57 |
Free Surface Flow - Tutorial 7
September 20, 2006, 20:23 |
If I only want to simulate single phase flow,and the material is constant density(not related by temperature or pressure),how should i do?
September 21, 2006, 01:27 |
If Buoyancy doesn't help you could program yourself a hydrostatic pressure - see also tutorial 7. Actually I don't understand your problem. Maybe you should be more precise.
September 21, 2006, 03:09 |
Thanks, For example, i 'd like to simulate a water siphon tunnel.you know the gravity is very important for this case. But as the explaination of CFX documents, the buoyancy is only affected by density change. in my case,the fluid material is constant density water.
September 24, 2006, 16:07 |
If you do not have two different phases in your model, then there is no need to include buoyancy. You have include the hydrostatic pressure differences in your pressure boundaries.
Astrid |
October 2, 2006, 03:53 |
There is the full buoyancy model and the Boussinesq approximation available in CFX. This info might be useful. Read CFX manual for this. TobiasZ
CFX gravity driven free surface flow tutorial | mechovator | CFX | 37 | July 27, 2009 10:28 |
Electronics Enclosure Analysis with CFX | Simulation Engineer | CFX | 1 | April 22, 2009 11:08 |
RE: Applying forces / Center of Gravity in CFX | Janusz | CFX | 1 | November 16, 2008 19:37 |
CFX 10's solutions differ from CFX 5.7's | Atit Koonsrisuk | CFX | 4 | July 26, 2006 11:59 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
