Lift and Drag on airplane wing
Old   October 5, 2006, 07:42
Default Lift and Drag on airplane wing
Arj
I am trying to run a simulation on wing designs to work out lift and drag coefficients. I am completely new to ANSYS CFX and Ive imported a wing geometry from solidworks to ANSYS. I am unsure how to go about this. I have made a containing box around my 3D model, what do i do from here, I tried to emulate flow around the wing by copying some parameters from the "flow around the blunt body" tutorial. All i have is some pretty colors around my wing. How can i measure velocities, pressures etc at specific sections of my wing. How do i determine lift and drag (forces?)using CFX and change angles of attack? Any help would be appreciated!
Old   October 5, 2006, 08:36
Default Re: Lift and Drag on airplane wing
Joe
You're on the right track. Just do all the tutorials and you will be able able to answer virtually all the questions you have posed, yourself.
Until you have a basic understanding of how CFX works any explanations by others wont really sink in.
Old   October 5, 2006, 12:09
Arj
cheers for the response! I understand that doing the tutorials is best, and I am endeavouring to do them in the limited time I have. However if possible, I would like a couple of small questions to be answered..Does ANSYS provide features(functions?) to work out lift and drag? Or do I need to manipulate the solved data, and use forces etc. Also how do I incorporate different angles of attack - Do I need to set my fluid flow from a different direction/angle?
Old   October 5, 2006, 13:35
Phil
It provides the XYZ components of force which you can then convert to Cl, Cd etc.
Change the fluid flow angle or the wing angle. Arrange your fluid BCs accordingly.
Old   October 6, 2006, 04:05
Michael B
For a start look at the overview at the end of the solver run.
lift and drag ceofficient problem icemaniac178 CFX 6 August 17, 2011 18:40
Reference Area for Calculating Lift and Drag Coefficient of 3D wing mahbub03 Main CFD Forum 3 May 19, 2011 00:21
Lift and Drag Monitor Point Values Converging to Zero Josh CFX 24 May 9, 2011 10:38
Point of lift / drag in a 3D wing simulate. SkunkWorks OpenFOAM Post-Processing 0 April 23, 2010 17:18
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 27, 2007 23:38
