Blademodeler and Fan
Like Tree1Likes
  • 1 Post By deLuther
Old   October 6, 2006, 03:32
Default Blademodeler and Fan
imothep
hi all how can transform XYZ coordinates of fan to meridional M-prime,Theta as bladgen input
Old   October 7, 2006, 04:33
Default Re: Blademodeler and Fan
deLuther
You can use rtzt file format if you just wish to import your geometry into bladegen. Assume you have pairs of XYZ coordinates (pressure side and suction side) by some layers. Then you already have Z coordinate. Second you can find middle point and thickness t from these pairs. And you can use coordinates of middle points to get r and theta. i.e. {xm,ym}={xp+xs,yp+ys}/2, t=sqrt((xp-xs)^2+(yp-ys)^2),r=sqrt(xm^2+ym^2),theta=arctan(ym/xm) Just see description of rtzt format in help and write convertor... This is my way.
sebaa likes this.
Old   October 7, 2006, 15:16
imothep
thanks deluther
Old   October 9, 2006, 06:15
deLuther
some addition to my previous post. I assume that Z goes through axis of rotation, X in direction of blade and Y in side direction. So sign consideration is important in particular case, my formulas is general. Layers according to bladegen principles. I made such thing once for radial compressor.
