-   -   how i can chart this along line towards two dire? (http://www.cfd-online.com/Forums/cfx/23152-how-i-can-chart-along-line-towards-two-dire.html)
prayskyer October 8, 2006 02:33
how i can chart this coordinate along this line towards two directions?
the X Direction coordinate is :there is a orign point=0, left side<0, right side>0.
my question is how that happen in CFX-POST? THANKS A LOT:)
http://img223.imageshack.us/img223/8586/asksl4.th.jpg
TB October 8, 2006 08:45
Re: how i can chart this along line towards two di
Assuming that you are charting velocity vs position:
1)Create a Line (under Location) using 2-point method etc.
2)Create a Chart, Select Type "XY", Define position as X-axis variable & velocity as Y-axis variable.
prayskyer October 8, 2006 21:45
thanks for your replying~!
sure,i creat a line using two points,and the X axis variable is the position along this line,~
but the problem is the "0" is the mid of the line, and the left side is negtive,and right side is positive,~
how can i deal with this? thanks a lot~
TB October 9, 2006 01:37
You want to shift the zero reference point to the other side of your line, don't you? If so, just create a new variable of say "Pos" and let the value be X+Xneg, where Xneg is the most negative value. Select Pos as your X-axis variable then.
prayskyer October 9, 2006 02:16
yes,i get what you mean~!
thinking of that line,if that is a curve,should i apply that coordinate transform,ture the curve to line?
and what are these really about,should i find some papers or books to find out?could you introduce some for me,really thanks:)
