simple export problem
Hi all !
I just started using ICEMCFD mesh generator. I have a simple problem when I write the solver file for CFX version 10 and find that when I choose the type of solver as ANSYS CFX. The program then produces a output file with extension .cfx5 which obviously does not work with CFX version 10. What do I need to do ? Thanks Steven |
Re: simple export problem
You have to load mesh as "ICEM CFD" (in CFX-Pre mesh format). The program (CFX) should recognize your ".cfx5" file. Pay attention to mesh units Ermanno |
If you run ICEM CFD in Workbench, you will get output file in .gtm format when you select ANSYS CFX as solver.
I think his problem should be solved by choosing the right format as Ermanno said.
