October 16, 2006, 20:28 |
How can use the different Fluid marerials
How can use the different Fluid marerials in the different domains?
October 17, 2006, 05:27 |
Re: How can use the different Fluid marerials
If the domains aren't touching, you can use a binary mixture, and set the value for vf of Fluid A to one and Fluid B to zero in the first domain, and set vf of Fluid A to zero and Fluid B to one in the other domain.
October 17, 2006, 05:53 |
Thanks for you answer! That's a good idea. Why I can't use Fluid A in one domain, and Fluid B in another domain? Thank you!
October 17, 2006, 08:10 |
Dear Kir, and Johnny
Though the approach sounds sensible and a lot of other codes do it that way, the problem is that the physical models must be the same on both domains.. Same turbulence model, reactions, etc.. If you are using ANSYS CFX 5.7.1 or 10.0, you can set an enviroment variable before starting CFX-Pre that will let you setup multidomain/physics/fluid cases. However, it is up to you that certain physics consistency checks are satisfied, ie. check your setup. The enviroment variable has been mentioned in this forum several times: CFX5_NO_CONSTANT_PHYSICS Good luck, Opaque.. |
October 17, 2006, 10:26 |
Thanks Opaque~!
How to use / How to find IPMT? | camoesas | CFX | 2 | November 23, 2010 06:36 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
My Revised "Time Vs Energy" Article For Review | Abhi | Main CFD Forum | 2 | July 9, 2002 09:08 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
