How can use the different Fluid marerials
Old   October 16, 2006, 20:28
Default How can use the different Fluid marerials
Kir
How can use the different Fluid marerials in the different domains?
Old   October 17, 2006, 05:27
Default Re: How can use the different Fluid marerials
Johnny
If the domains aren't touching, you can use a binary mixture, and set the value for vf of Fluid A to one and Fluid B to zero in the first domain, and set vf of Fluid A to zero and Fluid B to one in the other domain.
Old   October 17, 2006, 05:53
Kir
Thanks for you answer! That's a good idea. Why I can't use Fluid A in one domain, and Fluid B in another domain? Thank you!
Old   October 17, 2006, 08:10
opaque
Dear Kir, and Johnny
Though the approach sounds sensible and a lot of other codes do it that way, the problem is that the physical models must be the same on both domains.. Same turbulence model, reactions, etc..
If you are using ANSYS CFX 5.7.1 or 10.0, you can set an enviroment variable before starting CFX-Pre that will let you setup multidomain/physics/fluid cases. However, it is up to you that certain physics consistency checks are satisfied, ie. check your setup.
The enviroment variable has been mentioned in this forum several times:
CFX5_NO_CONSTANT_PHYSICS
Good luck,
Opaque..
Old   October 17, 2006, 10:26
Kir
Thanks Opaque~!
How to use / How to find IPMT? camoesas CFX 2 November 23, 2010 06:36
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
