-   CFX (
-   -   ICEM problem (
Ali October 27, 2006 08:54
ICEM problem
Hi all,
I'm simulating a wind tunnel test for a flow over hydrofoil. After making the mesh, I see mesh elements penetrate the foil with a small hole in the mesh around the foil end. Where is the problem? The foil has a top, bottom and side surfaces. Why the mesh inside the foil not around?
Any guides are welcome.
Robin October 27, 2006 10:03
Re: ICEM problem
If the top and bottom surfaces are very close, the projection algorithm in tetra may get them mixed up. To prevent this, define the top and bottom surfaces as a "thin cut". See the documentation for how to do this.
Ali October 27, 2006 10:31
Thanks Robin
Thanks Robin That's very helpful and fast.
