October 31, 2006, 06:29 |
VOF
Does the latest version of CFX has Volume of fluid method for fluid surface tracking. Can anyone comment on this aspect Thanks in advance |
October 31, 2006, 09:56 |
Re: VOF
This is a problem very important, because if you want tranking a interface bettween gas and liquid you need use this tecnic.
October 31, 2006, 10:04 |
Re: VOF
Yes, you can track a free surface in any current version of CFX using homogenous multiphase with free surface turned on. See the tutorials for details.
-Robin |
October 31, 2006, 11:38 |
Re: VOF
Hi Thandavanadhi,
just a clarification. The term interface tracking usually refers to methods which actually move the mesh: "Boundary fitted grids are used, and they are re-adjusted each time the free surface is used" Ferziger and Peric 2ed, p. 356 VOF methods fall in the category of Interface CAPTURING methods. CFX has the later...and it is very good. But not the former. Tell us more about your application and you may get some specific tips. Regards, Bak_Flow |
November 10, 2006, 23:22 |
Re: VOF
Dear Bak_flow
I want to model dam break problem in CFX. I would like to use VOF in CFX. In the multiphase simulation this option is not coming.. What method CFX uses .?. Thank you |
November 11, 2006, 13:20 |
Re: VOF
This is essentially what you get when you pick two fluids (i.e. Eularian-Eularian multiphase). There is a free surface tutorial (flow over a bump). Give it a try.
-Robin |
Display Modes | |
VOF Inlet condition | Rizwan | FLUENT | 15 | July 5, 2018 17:33 |
Question:Considerations about the evaporation in VOF | dokeun | FLUENT | 10 | February 24, 2011 21:47 |
vof + hydrostatic pressure | ariorus | FLUENT | 0 | August 7, 2009 11:57 |
urgent query regarding vof model plz rply | Garima Chaudhary | FLUENT | 0 | July 13, 2007 03:20 |
Difficult BCs about Freesurface Simulation by VOF | Yongguang Cheng | FLUENT | 0 | September 19, 2003 08:39 |
