October 31, 2006, 04:22 |
Can CFX handle local hex refinement?
i.e. is it possible to locally refine an unstructured hex mesh by local hex splitting? Fluent can handle this, can CFX without using manually defined interfaces etc?
October 31, 2006, 07:52 |
Re: Can CFX handle local hex refinement?
In CFX you will need to use generalized grid interfaces (GGIs) to handle such local refinements.
October 31, 2006, 09:00 |
..or remove the hanging nodes by conforming the mesh.
[ICEM] Hex refinement negative quality afterwards | Anorky | ANSYS Meshing & Geometry | 8 | March 22, 2010 03:25 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
CFX local support in singapore | Tej | CFX | 1 | September 23, 2002 09:38 |
Local grid refinement with CFX-Build 4.2? | Budi D | CFX | 0 | May 31, 2001 08:34 |
