Edges association in ICEM
Like Tree2Likes
  • 1 Post By johnny
  • 1 Post By Charles
Old   June 12, 2007, 18:34
Default Edges association in ICEM
Santiago Orrego.
Hello. Im doing a block mesh for a spiral case (turbines). Is there any way to remove the default association that puts ICEM to the curves, BUT avoiding the "No association" of the edge (that convert to blue color).
That is because when I deleted the default association the edge converts to blue, and all the edges association become crazy. (I need the white edge, but with no curve-point association).
Thanks. Santiago.
Old   June 12, 2007, 21:59
Default Re: Edges association in ICEM
johnny
You can associate an edge to a surface.
lukasf likes this.
Old   June 13, 2007, 15:14
Santiago Orrego.
yes, but when I associate that, I dont have any control, ICEM put me an association (wrong in my case). Thanks alot.santiago
Old   June 13, 2007, 16:33
Charles
You have to assign the face to the surface first, then the edges belonging to that face should associate to the correct surface.
Maerluz likes this.
Old   June 13, 2007, 19:58
Santiago Orrego.
Yes, it works, Thanks a lot! santiago.
Old   July 15, 2020, 14:06
Lightbulb Edges association in ICEM CFD
ANGELO
angelooo is on a distinguished road
I am doing a block mesh for a disk inside a cylinder. I create a block and I split it into different parts, I also associate all the edges to the curves. Now after I saved my blocking I need to delete a specific edge association and I can't find the way to delete it. Is there any way to delete an edge association that already created?
Thanks, ANGELO
angelooo is offline   Reply With Quote
Old   July 15, 2020, 14:43
Henrique Stel
Stel is on a distinguished road
Thanks, ANGELO
What do you mean with "delete an edge association"? Do you want to disassociate one specific edge from the geometry? If so, on Blocking > Associate, search for the fifth option from left to right, "Disassociate from Geometry", click on the arrow to "select edge(s)", click with the left button on the edge you want to disassociate and confirm with the middle button.
Stel is offline   Reply With Quote
Old   July 21, 2020, 09:47
Default Edges association in ICEM CFD
ANGELO
Yes it works, thanks ,ANGELO
Old   July 26, 2020, 08:33
Smile ICEM MESH Problem
ANGELO
I am working on a project and I need to mesh a disk with a shaft inside a cylinder. The disk and the shaft are the solid domain and the cylinder is my fluid domain. I have managed to mesh the geometry on ICEM CFD by using the O grid function of the split block. I am checking the quality of my mesh and I see that the outlet of my cylinder doesn't look good (like there is no o grid on the outlet) even though the number of nodes and the blocks are the same as the inlet. You can see the photos of my blocks and my mesh attached.
I don't know if the problem comes from the O grid or from the associations of my edges at the outlet?
Thanks, Angelo
Old   July 26, 2020, 10:41
Henrique Stel
If I understood your splitting correctly, you are trying a quadruple O-Grid. Why so many? It doesn't seem that you need all of them. Notice that the edges of the two outermost ones at the bottom are very close to each other. It doesn't look like a pure edge association problem but judging just from the images is hard to tell for certain. If I were you I would start all over again.
Plus: this geometry is way easier to mesh using the 2D to 3D (rotation) meshing strategy. See the ICEM documentation for further advice.
An important piece of advice: post your meshing questions in the ANSYS Meshing and Geometry forum, there is the right place to do so since you get a bigger chance of specialists seeing your question and also others having the same problem may benefit from the answer.
Old   July 26, 2020, 11:45
M
AtoHM is on a distinguished road
It looks fine from the one side (image 2) and bad from the other (image 1), right? Seems like the bunching is messed up there which happens sometimes when you split blocks. If that really is the problem, just use the tool to set the splits per edge and activate "copy to parallel edges" to get the same spacing at the top and bottom. But also check the associations.
AtoHM is offline   Reply With Quote
Aligned edges in ICEM RichardG ANSYS Meshing & Geometry 28 March 14, 2017 11:40
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
ICEM hexa mesh built with v10 deformed in v11 (degenerated edges) cfxicem ANSYS Meshing & Geometry 1 October 14, 2009 15:06
