November 25, 2006, 20:59 |
CFX 4.4 delay differential equation (DDE)
Hello all,
I am using CFX4.4, try to implement and solve a set of delay differential equations, does anyone know whether it is possible for the user to recall and use old variables, from varying and different time steps from the same simulation? If not, is there other methods to implement the DDE? Many Thanks, Joan |
May 16, 2019, 07:13 |
Zhiyuan Liu
Rep Power: 7 |
I also need help.
May 16, 2019, 08:13 |
Gert-Jan
Rep Power: 27 |
Do you really need help for implementing this in CFX4?
May 16, 2019, 10:52 |
Zhiyuan Liu
Rep Power: 7 |
Absolutely. I have created a new post with detail.
Add a lag correction equation |
May 16, 2019, 11:11 |
Gert-Jan
Rep Power: 27 |
You asked you question in an ancient query from 2006 when CFX had a structured version, called CFX 4.
Your new question (Add a lag correction equation) clearly shows you are using the newer unstructured version, called CFX 5. |
May 16, 2019, 21:35 |
#6 | |
Zhiyuan Liu
Rep Power: 7 |
May 17, 2019, 03:56 |
Gert-Jan
Rep Power: 27 |
Certainly, the physics remain the same but the software is completely different. Incomparable.
I don't know anyone that is using CFX 4. Too outdated. |
Solving Transport equation for additional variable using CFX | creddy_trddc | CFX | 11 | April 2, 2015 21:07 |
CFX Additional Variable Transport Equation | Scott Nordsen | CFX | 3 | January 30, 2010 05:36 |
Tecplot & CFX 4.4 | S. H. Kim | CFX | 3 | December 20, 2001 06:07 |
Programming turbulence models (CFX 4.4) | Hamsdi | CFX | 2 | October 12, 2001 01:14 |
Use of 1 equation turbulence model in CFX 4.3 | Niels Deen | CFX | 0 | July 19, 2000 08:50 |
