problems with batch-file, queue of jobs
Old   November 24, 2006, 08:42
Default problems with batch-file, queue of jobs
Stephan
I want to run several jobs over the weekend, the following one should start when the latter has finished.
I tried the following command line starting from my working directory in the launcher
D:\workingDIR>cfx5solve -def cfx1.def -initial cfx1.res
and it worked fine.
How do I queue the other jobs?
"D:\workingDIR>cfx5solve -def cfx1.def -initial cfx1.res cfx5solve -def cfx2.def -initial cfx2.res" did not work
neither did anything else I tried.
Please help!
Old   November 24, 2006, 10:01
Default Re: problems with batch-file, queue of jobs
Robin
Put each command in separate lines in a .bat file, then run the bat file. The next line will not execute until the first cfx5solve process exits.
Old   November 27, 2006, 12:14
Bian
I always use a perl script. It seems I can use a bat file to do the same thing.
Old   November 28, 2006, 04:20
Michael B
It's documented at the ANSYS CFX Community web pages. Look for "Running solver jobs in batch and job scheduling"
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
