Mesh only one surface in ICEM
Hello, Is it to possible to mesh only one surface when using the "surface meshing"-option in ICEM?
Thanks /Daniel |
Re: Mesh only one surface in ICEM
Yup. Just select the surface you want meshed.
But HOW do you select a surface? When I am pressing the surface meshing button I don't get a choice of choosing a surface
/Daniel |
check the display tree, surfaces must be active or in selection panel gets displayed you will be having options like points/curves/sufaces in icons check this also. regards aero |
