How do I set lower temperature boundary limit? |
December 4, 2006, 02:36 |
Hi
I am doing a steady state couple field electro-thermal analysis in ANSYS. I would like to set lower boundary limit for temperature for the thermal element i.e, temperature should not go below certain temperature. It can be free to assume any higher temperature value. Could you please inform me how can I accomplish this? Thanking you, Arefin Anwar Concordia University |
December 4, 2006, 09:48 |
Re: How do I set lower temperature boundary limit?
You could try to set you boundary temperature via the expression: Tbound=T*step(T-Tlow)+Tlow*step(Tlow-T). Where Tlow is your fixed minimal Temperatur and T is the variable temperature of your boundary.
How to set the Heat Flux boundary condition at Outlet | creddy_trddc | CFX | 3 | September 21, 2011 07:44 |
How to show the transient case? | H.P.LIU | Phoenics | 7 | July 13, 2010 04:31 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Water vapour condensation in CFX-5.7.1 | hdj | CFX | 1 | November 27, 2005 07:15 |
