GRID import MACRO
Old   December 1, 2006, 15:44
Default GRID import MACRO
Vishwas Iyengar
Hey,
My 2nd post on this topic, hopefully someone can help me. I need to upload my blade sections into ANSYS, they are in PLOT3D format. I was wondering if anyone has a macro or method to carry out this import.
Cheers, Vishwas gtg874k@mail.gatech.edu
Old   December 4, 2006, 12:51
Default Re: GRID import MACRO
Robin
Hi Vishwas,
There is an unsupported Plot3D import in the CFX installation. To use it, pick the "User Import" format and under the Advanced Options tab specify the Exec Location as "C:/Program Files/ANSYS Inc/CFX/CFX-10.0/bin/winnt/ImportPlot3d.exe", substituting 'winnt' with the appropriate OS. You should be able to manually locate this in your installation. The only problem is that the Plot3D format does not include any 2D regions and until CFX-Pre 11.0 comes out, you will not be able to define these regions.
Your best bet would be to load the mesh in to the ICEM CFD mesh editor where you can define the 2D regions you need. You can then export it from ICEM CFD to CFX.
If you don't have ICEM CFD and your mesh is coming from another code, try using a different intermediate format such as CGNS or Patran Neutral or any other format the codes have in common.
Regards, Robin
Old   December 5, 2006, 15:45
Vishwas Iyengar
thanks!
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Grid refinement. Sas Main CFD Forum 8 September 2, 2005 08:36
Fine grid embedding Philip Peeples Phoenics 1 July 3, 2002 18:32
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Numerical methods for discontinuous grid interfaces? Hansong Hang Main CFD Forum 12 September 16, 1998 22:26
