Home > Forums > CFX
Pausing CFX run
Old   December 6, 2006, 10:51
Default Pausing CFX run
Sheeko
Hello, I am running a CFX run on a laptop and I need to pause it so I can take the computer somewhere else. Is it possible to pause a simulation while running? Would it be possible to put the computer into hibernation or standby while the simulation is running and it would resume when the computer is back on?
Old   December 6, 2006, 17:42
Default Re: Pausing CFX run
I think so. Try it and find out.
Old   December 7, 2006, 07:09
Sheeko
It works ... if you put the computer into hibernation, the simulation will resume normally when u turn it back on again .. thanx
Old   December 7, 2006, 14:03
Miguel
You can stop the run from Solver Mannager, this will generate a .res file. You can turn off your laptop and restart later, for this define a new run, select same .def and select .res as Initial Values File.
Also you can restart a run from a .back file instead a .res file.
Regards
Old   December 7, 2006, 17:28
Also I am not sure how the license manager will respond to a run going into hibernation. If the laptop is the license manager then it is no problem but if you use another machine as a license server you may have licensing problems.
Thread Tools
Trackbacks are On
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 03:38
Error in CFX Run safikhani_hamed CFX 11 August 17, 2011 18:31
How to run CFX for inviscid cases? MouseInMilk CFX 4 July 28, 2006 23:56
How to make the solver of CFX run automate Jane CFX 4 April 10, 2006 14:42
How to run CFX on the background? David CFX 1 January 19, 2004 17:24
