December 8, 2006, 20:38 |
Thin Surface not taken
Hello! I am simulating a combustion chamber and the guide vanes in the inlet are set as a wall. When I simulate it, the flow doesn't take this condition and the flow goes through this surfaces. I have tried several ways, but it says in the out file that the boundary condition is a wall in the vanes, but the stream lines and everything are not consistent with this..
Does somebody have had this problem? What could be causing this? I have tried with the option of thin surface and with out this option and i get the same problem. Any sugestion would be very appreciated! Thanks! Maria Angelica |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
