December 11, 2006, 11:10 |
CFX meshing with Workbench
Dear all,
I have a small conductor in a coil full with water. My question is do I have to create the Water as a solid in order to mesh it in Workbench CFX mesh or to leave the space between the conductor and the tube walls empty. I want to see the temperature distribution in the conductor, so apart form meshing the water region I have to mesh the conductor and the tube as well. Thanks a lot |
December 19, 2006, 14:35 |
Re: CFX meshing with Workbench
If I understand your question right you need to create a fluid domain for the water and a solid one for the conductor and then create a fluid-solid interface between them.
One should define a region called "waterface" in workbench and one called "conductorface" to make the interface connection process easier. This only gives you the conductor and water region. If you want the tube as well then you need to mesh it, create a solid domain and interface it with the rest.... |
Display Modes | |
Remeshing in CFX using workbench meshing. | adeban | CFX | 25 | March 29, 2021 05:46 |
CFX (Workbench) 3D Hard-Disk Space ERROR | Engineers | CFX | 7 | October 17, 2011 21:25 |
Parallel meshing using XP64 with PVM in CFX Mesh | Huw | ANSYS Meshing & Geometry | 4 | July 12, 2010 10:24 |
Export Heat Flux CFX -> ANSYS Workbench | Freeman | CFX | 2 | April 11, 2010 08:24 |
CFX meshing | moon1234 | CFX | 0 | January 24, 2010 06:43 |
