-   -   Vessel Residence Time Distribution Help (http://www.cfd-online.com/Forums/cfx/23403-vessel-residence-time-distribution-help.html)
Davo December 10, 2006 05:00
Can someone please step me through how to calculate the residence time of water in a settling tank? I have read about creating an additional variable RTD and analysing the spatial distribution at the outlet, but I do not know how to do this.
Any help would be greatly appreciated.
Thanks Davo
Joe December 10, 2006 09:58
Re: Vessel Residence Time Distribution Help
Help manual: Look at the user cel and user fortran examples. One is for an RTD.
Davo December 11, 2006 06:39
I have modified tutorial 1 Static Mixer Transient and added a Additional Variable, but am unsure if the source point and boundary conditions are setup correctly. Here is the CCL, can someone point me in the correct direction please as I am pretty sure the Source Point 1 is not correct, it is meant to be 1 [s/s] but I cannot get it to accept that.
Thanks Davo
FLOW: DOMAIN:Default Domain
Coord Frame = Coord 0
Domain Type = Fluid
Fluids List = Water
Location = Assembly
BOUNDARY:in1
Boundary Type = INLET
Location = in1
BOUNDARY CONDITIONS:
ADDITIONAL VARIABLE:advRTD1
Additional Variable Value = 0 [s]
Option = Value
END
FLOW REGIME:
Option = Subsonic
END
HEAT TRANSFER:
Option = Static Temperature
Static Temperature = 315 [K]
END
MASS AND MOMENTUM:
Normal Speed = 2 [m s^-1]
Option = Normal Speed
END
TURBULENCE:
Option = Medium Intensity and Eddy Viscosity Ratio
END
END
END
BOUNDARY:in2
Location = in2
Option = Value
END
FLOW REGIME:
Option = Subsonic
END
HEAT TRANSFER:
Static Temperature = 285 [K]
END
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY:out
Boundary Type = OUTLET
Location = out
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Average Static Pressure
Relative Pressure = 0 [Pa]
END
PRESSURE AVERAGING:
Option = Average Over Whole Outlet
END
END
END
BOUNDARY:Default Domain Default
Boundary Type = WALL
Location = F1.B1.P3,F2.B1.P3,F4.B1.P3,F5.B1.P3,F6.B1.P3,F8.B1 .P3
HEAT TRANSFER:
Option = Adiabatic
END
WALL INFLUENCE ON FLOW:
Option = No Slip
END
WALL ROUGHNESS:
Option = Smooth Wall
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
Reference Pressure = 1 [atm]
END
END
FLUID MODELS:
Option = Transport Equation
END
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Option = Thermal Energy
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = k epsilon
END
TURBULENT WALL FUNCTIONS:
Option = Scalable
END
END
INITIALISATION:
Option = Automatic
INITIAL CONDITIONS:
Velocity Type = Cartesian
Option = Automatic with Value
END
CARTESIAN VELOCITY COMPONENTS:
U = 0 [m s^-1]
V = 0 [m s^-1]
W = 0 [m s^-1]
END
K:
END
STATIC PRESSURE:
Relative Pressure = 101325 [Pa]
END
TEMPERATURE:
Temperature = 300 [K]
END
END
END
SOURCE POINT:Source Point 1
Cartesian Coordinates = -0.829942 [m], -3 [m], 0.829942 [m]
Option = Cartesian Coordinates
SOURCES:
EQUATION SOURCE:advRTD1
Option = Total Source
Total Source = 1 [m^3]
END
END
END
SUBDOMAIN:subDom
Location = Assembly
END END INITIALISATION:
Option = Automatic
INITIAL CONDITIONS:
END
Option = Automatic
END
EPSILON:
Option = Automatic
END
K:
Option = Automatic
END
STATIC PRESSURE:
Option = Automatic
END
TEMPERATURE:
Option = Automatic
END
END END OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
TRANSIENT RESULTS:Transient Results 2
Option = Standard
Time Interval = 0.1 [s]
END END SIMULATION TYPE:
Option = Transient
INITIAL TIME:
Option = Value
Time = 0 [s]
END
TIME DURATION:
Option = Total Time
Total Time = 5 [s]
END
TIME STEPS:
Option = Timesteps
Timesteps = 0.1 [s]
END END SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s] END SOLVER CONTROL:
ADVECTION SCHEME:
Option = Upwind
END
CONVERGENCE CONTROL:
Maximum Number of Coefficient Loops = 10
Timescale Control = Coefficient Loops
END
CONVERGENCE CRITERIA:
Residual Target = 1.0E-4
Residual Type = RMS
END
EQUATION CLASS:av
ADVECTION SCHEME:
Option = High Resolution
END
END
TRANSIENT SCHEME:
Option = Second Order Backward Euler
END END END
LIBRARY: ADDITIONAL VARIABLE:advRTD1
Option = Definition
Tensor Type = SCALAR
Units = [ s]
Variable Type = Volumetric END
Jayani Anurangi December 19, 2006 04:36
I am a university student and I am designing a waste water treatment plant for our university canteen. It is a group project and my part of design is equalisation tank.According to our data, our canteen water has some amount of oil. Therefore we disided to treat oil by using saponification process. Then it is depolimerised and treated by using microorganism. We are interested to do saponification process at equalisation tank. Another thing is there are some amounts of solid things in canteen stream. So we want to sediment these things at equalisation tank. So I want to know how to find the residence time for our equalisation tank by considering two things mentioned.Thanks
