Improve accuracy on air foil blade simulation?
Old   December 11, 2006, 11:32
Default Improve accuracy on air foil blade simulation?
Bian
I am working on simulations for centrifugal fans with air foil blades. The predicted overall performance of the fan(e.g. total pressure rise, brake horse power, total efficiency) is much off from the test results. The error is about 10%, which seems big. Any advice on this kind of case to improve the simulation accuracy?
I would say this is special for ail foil blades. When the blades is single thickness curved plates, I can get very close results (predicted value is within 3-5% error comparing to test value)
Thanks,
Bian
Old   December 11, 2006, 13:25
Default Re: Improve accuracy on air foil blade simulation?
Jonas Pedro Caumo
Hello Bian, have you ever tried to test first only the airfoil blade ? then you test the entire fan ? A very hard thing to get the value in airfoil blades is the drag. For this simulations is good to use hex and O-grid type. And define in a very good way your boundary layer. These problens are not easy get to a very good accuracy, because it is specific and need a good computer as you get near and near to the test (experimental) results. Thanks. I hope this will help you a little bit.
Old   December 11, 2006, 14:54
Bian
Thanks, Jonas.
I did not test the airfoil blade first. Actually, it is hard to define the attack angle of the flow, which is varying along the blade height.
It seems airfoil needs much better surface and near wall mesh to get better simulation results, in which Hex and O-grid can help. Unfortunately, I can only generate Tetra and Prism meshes.
I think the best way is to simualte the airfoil blade itself first with good mesh. After getting resonable results, then put the blades into the fan wheel and keeping the meshes near around the blade. Is there an easy and better way, or a shortcut?
Bian
Old   December 11, 2006, 20:49
Johnny
Have you done mesh refinement study? What turbulence model are you using - SST?
Old   December 12, 2006, 11:29
Giovan
Bian,
I have been working on simulating fan performance as well and would like to share thoughts/questions. could you contact me at 845-679-1583. Thanks!
Giovan
Bearing and air simulation R.Escartin CFX 1 December 12, 2011 07:03
could anybody help with Ansys blade simulation? fredfalcao Main CFD Forum 0 December 9, 2009 05:49
Axial blade simulation, TurboGrid a must? Gentry CFX 1 March 19, 2009 10:20
air particle simulation software kong Main CFD Forum 0 February 11, 2006 22:33
air jet simulation Yue zou Main CFD Forum 0 September 28, 1998 08:30
