Home > Forums > CFX
How to generate one-to-one connections?
Old   December 13, 2006, 06:21
Default How to generate one-to-one connections?
Timmy
I hope that this is not too stupid. I have to solve a heat transfer problem in which I use four seperate domains - three solids and one fluid. To be sure that the heat transfer from solid to fluid and other way round is calculated very well I want to use 1:1 connections at the domain interfaces. At first I meshed the fluid domain (tet+prism with ICEM 10.0.1) and then cut out the surface meshes that build the interfaces with the three solids. Afterwards I used these cut-out shells to mesh the solid domains (with "from mesh & geometry"-option). Now as I try to make up one-to-one connections in cfx-pre the program responds with an error message when writing out the def-file. It says that it is only possible to do GGI-connections. I checked the surf-meshes at the interfaces but they fit perfectly. Even when I set the mesh fitting tolerance to 0.02 (the highest recommended tolerance due to the manual) the error message appears. Does anybody have an idea what I could have done wrong?
Thanks a lot,
Timmy
Old   December 13, 2006, 09:49
Default Re: How to generate one-to-one connections?
Joe
Use the mesh conformality option in edit mesh - merge menu in ICEMCFD.
Thread Tools
Trackbacks are On
Generate a CFD domain from FEA results Dave442 Main CFD Forum 0 August 3, 2011 12:42
How to generate this kind of grid with slope bottom lin OpenFOAM Native Meshers: blockMesh 3 January 18, 2011 05:56
how to generate moving meshes (please tell me) kiyono OpenFOAM 0 December 7, 2010 05:49
How to generate a atmospheric boundary layer Morten Andersen CFX 3 January 16, 2007 07:48
how to generate postscript file? leo CD-adapco 6 May 27, 2003 23:38
