December 15, 2006, 22:45 |
why CFX help can't work?
when i turn the help on, it can't work!!!
the box's message like this: error reture from help viewer,intialiseJAReader:Envionment variable CFX5JAVE not set. why this happen,could anyone help me~~~ |
December 16, 2006, 08:33 |
Re: why CFX help can't work?
Try installing the latest JAVA Virtual Machine, seems like your system doesn't have one.
December 16, 2006, 10:44 |
You can also find PDF's of the documentation in the CFX installation under <CFX ROOT>/help/pdf. As Omar said, however, the problem is probably that you don't have the JAVA machine installed or need an update.
-Robin |
December 16, 2006, 20:32 |
seems i can download that machine from the internt,
thanks a lot |
December 16, 2006, 20:50 |
can't work, is there other problems could happen?
December 17, 2006, 16:15 |
Should have worked. Do you have the latest one? Now that you have JVM, and things aren't working anyway. Try to install CFX again! ( Before doing so, check from your task manager, if JAVA.exe is running or not!)
OpenFOAM vs. Fluent & CFX | marco | FLUENT | 16 | November 17, 2020 04:53 |
CFX vs. Fluent | George | FLUENT | 43 | May 15, 2012 23:42 |
OpenFOAM vs. Fluent & CFX | marco | Main CFD Forum | 81 | March 31, 2009 14:22 |
Importing solutions in CFX. | Alphonso | CFX | 1 | August 1, 2008 14:01 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
