-   -   SST in 2D? (http://www.cfd-online.com/Forums/cfx/23442-sst-2d.html)
Jesper Sørensen December 19, 2006 05:34
SST in 2D?
Hey everybody
Im working on a 2D simulation (one element thick) in CFX (ansys 10), and I have run my simulation of flove round a bridge profile with a K-omega model - but know that the SST model simulates seperation better - but is it possible to use this model in CFX on my 2D model? I havent been able to make i work.
I have symmetry conditions on my boundaries.
Thanks i advance
Jesper
Joe December 19, 2006 08:53
Re: SST in 2D?
You can use SST in 2d.
Jesper Sørensen December 19, 2006 10:39
Re: SST in 2D?
Tanks for that notice Joe
- but I cant make it work for my 2D model - but i has a nice convergence when i use both K-omega and K-epsilon models. Any input to why i cant make the SST model work then?
Tanks in adwance
Jesper
Fusion December 19, 2006 11:05
Re: SST in 2D?
Hi Jesper,
SST model works well as any other model in 2D, I never had problems with this. What means "I cant make it work"? Stability, convergence problems or something else?
Fusion
Omer December 19, 2006 17:09
Re: SST in 2D?
As Fusion said, it makes no sense to say that other models work and SST doesn't. If they work, so should SST. Check how fine your mesh is, maybe refine it especially at the boundaries. Can't think of anything else.
zxaar December 19, 2006 19:45
Re: SST in 2D?
keep your yplus very low (around 1) and sst will also work. If your yplus is high the implementation of sst in CFX can give you uncorrect answers. If your yplus is already low, then I do not know what could be the issue. It should be working well.
Jesper Sørensen December 20, 2006 03:06
Re: SST in 2D?
tanks everybody for your responses!
"cant make it work" means that i terminates with an error befor the itterations even starts. My Yplus value is 1.6 and should be suficient - rigth? I agree with you - it just dosent make sense.
But thanks anyway.
Jesper
Jesper Sørensen December 20, 2006 04:50
Re: SST in 2D?
I have now changede my advection scheme to Upwind, used and extremly small time step and refined my mesh so tha yPlus is around 1. Now the SST-models starts, but terminates after only 15 itterations due to "fatal owerflow in linear solver". I am out of ideas...anybody?
Thanks in advance
Joe December 20, 2006 07:09
Re: SST in 2D?
The problem isnt the turbulence model.
Jesper Sørensen December 20, 2006 09:07
Re: SST in 2D?
I know that the problem isnt the model itself, but i have no idea about what the problem then might be?
Fusion December 20, 2006 09:58
Re: SST in 2D?
Some possibilities: - Your mesh have some elements with too little volume (near 0); - You have some elements (hexahedrons I guess) with too high aspect ratio (say >100); - You are running transient calculation without checking the Courant number for the timestep; - You are running transient calculation with a really bad initialization; - something else...
good luck, Fusion
Joe December 20, 2006 12:30
Re: SST in 2D?
http://www.cfd-online.com/Wiki/Ansys...ible_answer.3F
Fusion December 20, 2006 12:50
Re: SST in 2D?
Great!
dear Jesper, I wish to underline that after 13 Messages I didn't understand yet what is your problem exactly. Try to give more detailed description.
Fusion
zxaar December 20, 2006 23:37
Re: SST in 2D?
well when the solver says fatal overflow in linear solver, it many times means division by zero. So when we look at the sst, there are few terms those can blow up if the omega goes to zero. (cross diffusion term being the one). When you say other turbulence models are working, do you mean the standard k-omega model too. Because the cross diffusion term is in std k-w model also. So if the problem coming becomes of that, that might also blow away. A good remedy to this would be to start with good initial guess. That you can get by exporting results from k-epsilon model. And read them in k-mega model as inital guess. We all can guess only, so this is one of them.
Jesper Sørensen December 21, 2006 04:56
Re: SST in 2D?
Hey everybody
I am very sorry if i have not formulated my problem clearly enough, and confusede the reader unnessesary. Sorry. But thank you very much for your responses anyway, and for making i clear to me, that the question is not directly enough.
Lets me try to make it better (if not know, then in the future.)I am a beginner here and in CFX and are very greatful for your help in this forum!
Here goes...
I am working on a bridge profile in 2D (one element thick), and whant to determin the lift and drag coefficients for this stationary problem. My problem is scaled 1:2. I have tried to run both the K-omega and K-epsilon and both of the runs very well with a good convergens rate - and therefor my question about the SST model (and BSL). I have limited myself to make it work in steadystat first.
Here is the indputs to the model: (if this helps making i clar, what i have done in my model - and if you have the time)
Thanks in adwance - Jesper
Setting up CFX-5 Solver run ...
+---------------------------------------------------------- |CFX Command Language for Run
LIBRARY:
MATERIAL: Air Ideal Gas
Material Description = Air Ideal Gas (constant Cp)
Material Group = Air Data, Calorically Perfect Ideal Gases
Option = Pure Substance
Thermodynamic State = Gas
PROPERTIES:
Option = General Material
ABSORPTION COEFFICIENT:
Absorption Coefficient = 0.01 [m^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Molar Mass = 28.96 [kg kmol^-1]
Option = Ideal Gas
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
SPECIFIC HEAT CAPACITY:
Option = Value
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 0. [J/kg]
Reference Specific Entropy = 0. [J/kg/K]
Reference Temperature = 25 [C]
Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 2.61E-2 [W m^-1 K^-1]
END
END
END END EXECUTION CONTROL:
PARALLEL HOST LIBRARY:
HOST DEFINITION: jesper
Installation Root = C:\Programmer\ANSYS Inc\CFX\CFX-%v
Host Architecture String = intel_pentium_winnt5.1
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Independent Partitioning
Runtime Priority = Standard
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
END
END
RUN DEFINITION:
Definition File = C:/9.semester/New Folder 1/test_3.def
Interpolate Initial Values = Off
Run Mode = Full
END
SOLVER STEP CONTROL:
EXECUTABLE SELECTION:
Double Precision = Off
END
MEMORY CONTROL:
END
PARALLEL ENVIRONMENT:
Number of Processes = 1
Start Method = Serial
END
END END FLOW:
DOMAIN: halfscale
Coord Frame = Coord 0
Domain Type = Fluid
Fluids List = Air Ideal Gas
Location = Assembly 2
BOUNDARY: Inlet1
Boundary Type = SYMMETRY
Location = INL.1 2
END
BOUNDARY: Inlet2
Boundary Type = INLET
Location = INL.2 2
BOUNDARY CONDITIONS:
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Cartesian Velocity Components
U = 46 [m s^-1]
V = 0 [m s^-1]
W = 0 [m s^-1]
END
TURBULENCE:
Option = Medium Intensity and Eddy Viscosity Ratio
END
END
END
BOUNDARY: Inlet3
Location = INL.3 2
END
BOUNDARY: Outlet
Boundary Type = OUTLET
Location = OUT 2
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Static Pressure
Relative Pressure = 0 [Pa]
END
END
END
BOUNDARY: Wall1
Location = WALL.1 2
END
BOUNDARY: Wall2
Location = WALL.2 2
END
BOUNDARY: Body
Boundary Type = WALL
Location = HALF SCALE 1 1 2
WALL INFLUENCE ON FLOW:
Option = No Slip
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
REFERENCE PRESSURE:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Fluid Temperature = 288 [K]
Option = Isothermal
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = SST
END
TURBULENT WALL FUNCTIONS:
Option = Automatic
END
END
END
OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
END
SIMULATION TYPE:
Option = Steady State
END
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
SOLVER CONTROL:
ADVECTION SCHEME:
Option = High Resolution
END
BODY FORCES:
Body Force Averaging Type = Volume-Weighted
END
CONVERGENCE CONTROL:
Maximum Number of Iterations = 200
Physical Timescale = 0.005 [s]
Timescale Control = Physical Timescale
END
CONVERGENCE CRITERIA:
Conservation Target = 0.01
Residual Target = 1.E-4
Residual Type = RMS
END
DYNAMIC MODEL CONTROL:
Global Dynamic Model Control = Yes
END
EQUATION CLASS: continuity
ADVECTION SCHEME:
END
END
END
EQUATION CLASS: momentum
ADVECTION SCHEME:
END
END
END
EQUATION CLASS: ke
ADVECTION SCHEME:
Option = Upwind
END
END
EQUATION CLASS: tef
ADVECTION SCHEME:
Option = Upwind
END
END
INTERPOLATION SCHEME:
Pressure Interpolation Type = Linear-Linear
Shape Function Option = Parametric
Velocity Interpolation Type = Trilinear
END
PRESSURE LEVEL INFORMATION:
Compressible Transient Option = Shift Pressure
Option = Automatic
Pressure Level = 0 [atm]
END
END END COMMAND FILE:
Version = 10.0
Results Version = 10.0 END
+--------------------------------------------------------------------+ | | | Solver | | | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | | | ANSYS CFX Solver 10.0 | | | | Version 2005.07.11-10.24 Mon Jul 11 10:26:04 GMTDT 2005 | | | | Executable Attributes | | | | single-32bit-optimised-supfort-noprof-nospag-lcomp | | | | Copyright 1996-2005 ANSYS Europe Ltd. | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | Job Information | +--------------------------------------------------------------------+
Run mode: serial run
Host computer: JESPER Job started: Thu Dec 21 10:50:56 2006
+--------------------------------------------------------------------+ | Memory Allocated for Run (Actual usage may be less) | +--------------------------------------------------------------------+
Data Type Kwords Words/Node Words/Elem Kbytes Bytes/Node
Real 78083.6 299.75 600.74 305014.0 1199.00 Integer 18687.4 71.74 143.77 72997.5 286.95 Character 2327.7 8.94 17.91 2273.1 8.94 Logical 40.0 0.15 0.31 156.2 0.61 Double 1208.0 4.64 9.29 9437.5 37.10
+--------------------------------------------------------------------+ | Total Number of Nodes, Elements, and Faces | +--------------------------------------------------------------------+
Domain Name : halfscale
Total Number of Nodes = 260496
Total Number of Elements = 129980
Total Number of Hexahedrons = 129980
Total Number of Faces = 260496
+--------------------------------------------------------------------+ | Reference Pressure Information | +--------------------------------------------------------------------+
Domain Group: halfscale
The pressure level is set by the following boundary condition:
Boundary Patch Name : Outlet
However, pressure level information has also been set.
The specified information will be ignored.
+--------------------------------------------------------------------+ | Average Scale Information | +--------------------------------------------------------------------+
Global Length = 1.5665E+01
Minimum Extent = 1.0000E-02
Maximum Extent = 6.2000E+02
Density = 1.2254E+00
Dynamic Viscosity = 1.8310E-05
Velocity = 4.6000E+01
Advection Time = 3.4053E-01
Reynolds Number = 4.8225E+07
Speed of Sound = 3.4027E+02
Mach Number = 1.3519E-01
+--------------------------------------------------------------------+ | Checking for Isolated Fluid Regions | +--------------------------------------------------------------------+
No isolated fluid regions were found.
+--------------------------------------------------------------------+ | The Equations Solved in This Calculation | +--------------------------------------------------------------------+
Subsystem : Wall Scale
Wallscale
Subsystem : Momentum and Mass
U-Mom
V-Mom
W-Mom
P-Mass
Subsystem : TurbKE and TurbFreq
K-TurbKE
O-TurbFreq
CFD Solver started: Thu Dec 21 10:51:49 2006
+--------------------------------------------------------------------+ | Convergence History | +--------------------------------------------------------------------+
================================================== ==================== | Timescale Information | ---------------------------------------------------------------------- | Equation | Type | Timescale | +----------------------+------------------------+--------------------+ | U-Mom | Physical Timescale | 5.00000E-03 | | V-Mom | Physical Timescale | 5.00000E-03 | | W-Mom | Physical Timescale | 5.00000E-03 | | P-Mass | Physical Timescale | 5.00000E-03 | +----------------------+------------------------+--------------------+ | K-TurbKE | Physical Timescale | 5.00000E-03 | | O-TurbFreq | Physical Timescale | 5.00000E-03 | +----------------------+------------------------+--------------------+
================================================== ==================== OUTER LOOP ITERATION = 1 CPU SECONDS = 1.492E+01 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | Wallscale | 0.00 | 1.3E-07 | 2.0E-07 | 7.3 1.2E+01 F | +----------------------+------+---------+---------+------------------+ | U-Mom | 0.00 | 1.7E-03 | 5.3E-02 | 4.0E-02 OK| | V-Mom | 0.00 | 2.9E-04 | 1.2E-02 | 3.7E-01 ok| | W-Mom | 0.00 | 0.0E+00 | 0.0E+00 | 0.0E+00 OK| | P-Mass | 0.00 | 5.7E-03 | 2.6E-01 | 12.2 3.3E-02 OK| +----------------------+------+---------+---------+------------------+ | K-TurbKE | 0.00 | 1.3E-01 | 1.9E-01 | 5.8 1.8E-08 OK| | O-TurbFreq | 0.00 | 1.1E-02 | 1.0E+00 | 10.5 2.2E-08 OK| +----------------------+------+---------+---------+------------------+
Joe December 21, 2006 07:50
Re: SST in 2D?
Could be your BCs. Could be a transient problem you are shoehorning into SS. You have a couple of odd parameter selections Could be near wall mesh.
Need pic of the mesh + BC locations including closeup of the boundary layer region.
Jesper Sørensen December 23, 2006 08:40
Re: SST in 2D?
Hey Joe. I have don a transient simulation, and the result is the same.
For some reason i cant post pictures of the mesh here - but if you could giv me an email adr. I would like to send you the pic of the mesh.
Thanks
Jesper
