Workbench on Linux Segmentation Fault
I'm attempting to run ANSYS Workbench and/or Design Modeler 10.0 using
gcc version 4.1.0...... Linux version 2.6.16.21-0.25-default (SuSE 10.1) Unfortunately, I keep getting a Segmentation Fault whenever I try and start these programs. CFX10.0 works, but these do not. Has anyone ever had these problems or can suggest anyway of fixing them? |
Re: Workbench on Linux Segmentation Fault
AFAIK workbench isnt supported on linux? (Or is it just not supported on X86 linux???)
Have a look at the workbench install guide ... |
CFX 10 and EM64T, is it possible?
Question, are you using the CFX 10 for Linux AMD 64 install? I am asking because I am looking to run version 10 on and quad core Intel using SuSE, but am not sure if there is a version for linux that runs on the EM64T ? I need 64 bit for the memory requirements, any help would be good. Thanks Tony F
Re: CFX 10 and EM64T, is it possible?
AMD x64 executables should run fine on an Intel EMT64 AFAIK.
Excellent, thanks Tony
It runs but you need a minor, unofficial, patch to cfx 10. Contact your support rep.
EM64T is supported natively in CFX 11 I presume?
I ask because we are switching from Opterons to Xeons soon ... |
