Workbench on Linux Segmentation Fault
Old   December 19, 2006, 14:46
Default Workbench on Linux Segmentation Fault
John Smith
I'm attempting to run ANSYS Workbench and/or Design Modeler 10.0 using
gcc version 4.1.0...... Linux version 2.6.16.21-0.25-default (SuSE 10.1)
Unfortunately, I keep getting a Segmentation Fault whenever I try and start these programs. CFX10.0 works, but these do not.
Has anyone ever had these problems or can suggest anyway of fixing them?
Old   December 20, 2006, 07:11
Default Re: Workbench on Linux Segmentation Fault
Joe
AFAIK workbench isnt supported on linux? (Or is it just not supported on X86 linux???)
Have a look at the workbench install guide ...
Old   December 27, 2006, 05:16
Default CFX 10 and EM64T, is it possible?
Tony
Question, are you using the CFX 10 for Linux AMD 64 install? I am asking because I am looking to run version 10 on and quad core Intel using SuSE, but am not sure if there is a version for linux that runs on the EM64T ? I need 64 bit for the memory requirements, any help would be good. Thanks Tony F
Old   December 27, 2006, 14:16
Default Re: CFX 10 and EM64T, is it possible?
Joe
AMD x64 executables should run fine on an Intel EMT64 AFAIK.
Old   December 27, 2006, 17:22
Tony
Excellent, thanks Tony
Old   January 3, 2007, 00:05
HekLeR
It runs but you need a minor, unofficial, patch to cfx 10. Contact your support rep.
Old   January 3, 2007, 13:45
Joe
EM64T is supported natively in CFX 11 I presume?
I ask because we are switching from Opterons to Xeons soon ...
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 09:23
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 21:59
LINUX Experts: Help with installing ANSYS workbench faisal_durr ANSYS 1 May 30, 2014 08:07
Workbench 11-Linux Intel EM64T platforms Seg fault Maciej Karczewski CFX 5 April 19, 2010 03:37
ParaView segmentation fault only for multiphase gwierink OpenFOAM 9 March 25, 2010 07:23
