How to extrude 2D Mesh in ICEM CFD?
Like Tree1Likes
  • 1 Post By myron
Old   December 24, 2006, 07:05
Default How to extrude 2D Mesh in ICEM CFD?
VSB
I am trying to extrude a 2D Mesh from a simple square geometry
this is what i am doing
1. Create the 2D geometry ((a square ) in X-Y plane
2. create a 3D Bounding Box. Give equal no: of nodes for each edge and see the premesh.
3. then I create a "curve", normal to one of the "points" of the square (distance equal to the cell size in the Z-direction)
4. Unless I convert the current mesh to unstructured by right-clicking on premesh, I dont see the Extrude Mesh option in the Mesh tab highlighted. (Is this the case?)
5. I use Extrude Mesh by curve option to create the 3D Mesh
6. When I click export to CFX, I see a warning in ICEM box, "the family BODY has mixed of 2D and 3D elements and this is not allowed in CFX -5"
What does the above error mean?
Is the procedure that I am following right? I am not using the "Extrude by element normal" method as it is giving large thickness in the Z-direction. One more thing, when to define parts in such a problem so that I can select location for a Boundary Condition later in CFX?
I hope somebody responds to my queries
Old   December 24, 2006, 14:19
Default Re: How to extrude 2D Mesh in ICEM CFD?
Manu
You are doing 2D or 3D Simulation. If 2D than extruding one element thick in z or normal direction will definitely work. Procedure-> 1.Make 2D Geometry of Problem.Define Boundaries by parts. 2.Make a 2d Planar Block 3.Associate Edges to curve than associate vertices. 4.Specify no of nodes. 5.Premesh than convert the mesh into unstrutured(only the format) 7.Close Project.Than open only the mesh . 8.Extrude by normal method one element (2D) or more elementsif (3D Simulation.you can also define ur parts name in the extrude tool menu. 9.Save and import to CFX. I hope this will help and work.
Manu
Old   December 26, 2006, 03:34
VSB
Hi manu
Thanks a lot
But still everything doesnt seem to work as i want it to be
I am doing 3D simulation (Does CFX handle 2D simulations, I
dont think so.... My geometry doesnt require a 3D analysis,
so I want to make a 2D Mesh and extrude it to 3D
Please address the following things:
1. In the Extrude Mesh window that appears after clicking
on the icon, I select all the elements by typing "a". Even
If use the "Extrude by element normal" method with 1 layer
I see that the length/thickness/extrusion distance in the
third direction "z" is very large!!! Is there any means by
which this can be manipulated? Or is this absolutely
normal? Is there a way in which I can specify
the "extrusion distance" myself so that I can avoid this
system-default extrusion distance which in this case
appears to be very large...
2. In the Extrude Mesh window, there is provision for
defining part names. But it simply asks for name to be
given for the sides. In this case there are four sides but
not all of them will be assigned a similar boundary. I
could not make your "Define Bounadries by parts after
creating a 2D Geometry" strategy work
3. After exporting the mesh to CFX, I still see this
warning that " the body (name of the body that I created
before blocking) has mixed of 2D and 3D elements which is
not allowed in CFX -5" Can this warning be ignored
or does it have any impact?
Old   December 26, 2006, 08:41
myron
Once you have loaded the 2D mesh - just a surface mesh - look at the parts list. My guess is that the surface mesh is in the part where you originally defined your 'body' to be (for the blocking). You'll probably want to move this surface mesh into a part for the representative surface.
I believe CFX requires one-element-thick mesh for a 2D analysis.
Mesh > Extrude Mesh. The volume part name is for the newly-created 3D elements. The Side Part is for the 'sides' of the extrusion. The Top Part is for the opposite end of the extrusion (the 'end' of the extrusion). You specify the Number of Layers and the Spacing Type. The Spacing Type default is set to 'Fixed' and a Spacing of 1. If you want a smaller extrusion layer, change the 'Spacing' value to your desired thickness. If you specify more than one layer, each layer has the 'Spacing' value.
Once you have the extruded mesh you can use the Parts branch to separate the surface mesh into appropriate groups. (Create parts, add to parts, etc.)
PrincessAngina likes this.
Old   December 26, 2006, 23:11
VSB
Hi Myron, Thanks a ton for the detailed mail!
I actually wanted to decrease the spacing of my extruded
mesh.But I wrongly called it thickness, hence the confusion
Now I have given a value of 0.01 for spacing and found the
mesh to my satisfaction.
Even I am able to assign mesh to desired parts
I just have one more question.
Is the solution influenced by the spacing value?Ideally
what should be the spacing value?
I tried out a simple problem both in 3D and and by this way
of extruding a 2D Mesh. I find that the solutions in both
the above cases are sufficiently close to each other
But I want to know if something can be done to bridge the
difference. Or is it that way only because we are making an
approximation in the case of extruded mesh?
Old   December 27, 2006, 07:22
Manu
I think in 2D Simulation Extrude distance has no effect bcoz there are no nodes in between the two at ends. But in 3D ( i.e more no of nodes in z directioin)it will greatly influence the result and that will ofcourse depend on the physics of the problem.If you want to do a transient case than definitely you should consider the proper extrude distance. Hope this is what u want to now???
Manu
Old   December 27, 2006, 08:39
VSB
Hi Manu,
I am really not able to understand what u mean by 2D and 3D?
Are you talking in relevance to CFX? Isnt what u are
getting by extruding also a 3D Mesh?
Old   December 27, 2006, 11:58
Manu
yes its all revence to CFX.Since you can not do a 2D Simulation directly in CFX so we somehow have to make the code fool by giving an element thick mesh.Yes its a 3D Mesh but not 3D Simulation.Thats wht i meant in previous post.
ICEM CFD 5.0 - 2D to 3D Mesh Extrude James Date CFX 7 October 22, 2013 03:46
Loading previously saved mesh in ICEM CFD user0314 ANSYS Meshing & Geometry 1 September 20, 2011 12:46
[ICEM] Problem with volume mesh in ICEM CFD kolapoasafa ANSYS Meshing & Geometry 2 September 16, 2011 03:54
How to corse mesh in icem cfd? Priety CFX 2 October 2, 2006 03:57
