Execution Terminated: STP file found
Old   January 8, 2007, 14:54
Default Execution Terminated: STP file found
Rita
Anyone know what this means? I get this when I "STOP" a run, and it will not output any results file...
Thank you in advance
Old   January 8, 2007, 21:42
Default Re: Execution Terminated: STP file found
Trevor
I gather that when you pressed stop it generates this stop file. When the solver finishs a time step or iteration it checks for this file and if found then stops. If it is a transient run and you stop it before a results file time step is complete, then you will have no results file. In a steady state, I dont think a results file will be written either.
If you can, let the solver finish the run and then you will have a results file.
Regards Trevor
Old   January 8, 2007, 23:12
HekLeR
when you hit the stop button the results file is written in steady state (end of current outer loop) or transient (end of current timestep).
if not, then there must be a bug to report.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
