-   -   FINMES Error - Fatal Overflow in linear solver (http://www.cfd-online.com/Forums/cfx/23506-finmes-error-fatal-overflow-linear-solver.html)
Jacob January 10, 2007 09:43
I am trying to simulate Non-premixed Turbulent combustion
of Methane-Air Mixture using Finite Rate Chemistry model.
When I initialize the domain with low temperatures, the
solver runs to a converged solution but the reaction does
not ignite. When I initialize the domain to a higher
temperature (900 K) as suggested in the manual, I get the
following error "FINMES Error - Fatal Overflow in linear
solver". The same .def file works absoultely fine when EDM
model is used and gives good results. But when I use Finite
Rate Chemistry model, this error occurs.Even attempting to
start the run from a converged EDM solution does not help
All my mesh statistics like Edge length ratio,
connectivity, Min.Face angle etc are well below the
suggested values in the manual. No. of hexahedral elements
are about 25000. Can anybody throw light on where I could
be making a mistake?
Thanks
Jacob
