Ansys CFX Vs. NACA Summary Report. Mismatch Result |
January 12, 2007, 11:38 |
Hello. We are working on a NACA 4415 airfoil. We are trying to validate the model, making a comparation between the results from Ansys CFX and the summary report 824 from NACA, page 143.
The conditions of the NACA experimental Test are (if Im wrong please let me know): Re: 3e6 Density: 1.225 ???? kg/m3 Viscosity: 1.7986 ??? kg/m*s Chord= 2ft (0.6096m) Ref pressure= 1 atm ???? We assumed ISA conditions @ sea level. (if somebody know the conditions, please confirm us) In CFX the conditions are: Re:3e6 Density: 1.225 kg/m3 Viscosity: 1.7986 kg/m*s Chord of the airfoil= 2ft (0.6096m) Ref pressure= 1 atm alfa= 4º turbulence model= SST turbulence intensity= 5% turbulence wall function=automatic Gas ideal @ 15ºC for the iteration convergence: High resolution conservative max= 1e-4 autotimescale meshed in ICEM. C grid hex elements, we used edge spacing, leaving the same spacing and changing number of nodes in the three meshes. Hence: the results in CFX are: 1.Mesh: Elements 35466 - Y+:2.448 - Cd: 0.0301079 - Cl: 0.6131 2.Mesh: Elements 47886 - Y+:0.7881 - Cd: 0.029875 - Cl: 0.601245 3.Mesh: Elements 78606 - Y+:0.5475 - Cd: 0.0288936 - Cl: 0.589375 The results form NACA report are: Cl:0.81 Cd:0.0075 Can anybody can help us out? thanks for reading and contribuying. Santiago - Andres - Colombia. |
January 13, 2007, 12:00 |
Re: Ansys CFX Vs. NACA Summary Report. Mismatch Re
Hello Again. We modified some boundary conditions and we got more closer.
Cl= 0.78 Cd=0.013 The error in Cl is about 7%, but the error in the Cd is about 60%. Is this correct? its possible to get an error <10% in the Cd ? Thanks Santiago Andres |
February 5, 2007, 09:31 |
use transition model
February 5, 2007, 12:05 |
Thanks Mr Bill. Ww used Langtry Menter and it worked ok. We had problems with the convergence, but the results where ok. Thanks santiago
Problem in coupling CFX and Ansys for fluid-thermal sim. | Jordi | CFX | 21 | March 1, 2017 05:03 |
ANSYS CFX Tutorial | Rashid | CFX | 25 | December 20, 2012 01:22 |
How to import CFX mesh & result to ANSYS Structure | Ton | CFX | 2 | May 19, 2009 21:54 |
Ansys CFX bucket problem | njsavage | Main CFD Forum | 1 | April 30, 2009 09:48 |
CFX bought by Ansys - good or bad?! | Pete | CFX | 38 | February 21, 2003 07:34 |
