January 15, 2007, 11:38 |
Problems with Convergence
I'm having problems with convergence..I use a mesh with a Y+ of 0.65 before the implementation of the SST turbulence transition model... Then i use the transition model on the same mesh but the problem don't converge...any ideas? thanks in advance, Andres, |
January 16, 2007, 06:39 |
Re: Problems with Convergence
Before using the SST model which model did you use. Y+ of 0.65 seems to be too fine. Reduce it around 2-4 for SST. Could you also provide more details about your simulation as Y+ value may not be the problem for the non-convergence.
January 16, 2007, 07:58 |
Thanks Luke,
I'm analizing a NACA4415 and NACA4418 to choose the best one of them...the data are: - Re 3e6 - AoA 4 degree - ISA conds. thanks in advance for your time. |
Gas-liquid vertical separator, problems with convergence | juliom | Main CFD Forum | 0 | October 5, 2011 20:20 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
NACA0012 Convergence Problems | StudentAndrew | CFX | 6 | November 21, 2005 06:49 |
Convergence problems | Simone | Siemens | 5 | June 29, 2005 10:48 |
Convergence problems | Chetan | FLUENT | 3 | April 15, 2004 19:13 |
