Exporting Chart to jpg or png format
Old   September 1, 2015, 14:06
Default Exporting Chart to jpg or png format
beyonder
beyonder1 is on a distinguished road
Is there anyway to export charts in jpg or png format from CFD-Post.
beyonder1 is offline   Reply With Quote
Old   September 2, 2015, 02:26
Maxim
-Maxim- is on a distinguished road
Outline (left sidebar) - Report - right click and select 'publish'
check 'save images in separate folder'
in 'more options', you can set the quality of the PNGs/JPGs.
speaking of... does anyone know an easier way? Is there a way to export the charts as *.svg or some other vector graphic image? I guess it's better to export the csv and use the raw data directly in LaTeX for publishing...
-Maxim- is offline   Reply With Quote
Old   September 2, 2015, 02:47
beyonder
Thanks for the reply.
Actually I want to generate charts for large no. of timesteps. So according to solution provided by you, when i generate for other timestep, it overwrites on previous one. Do you any other way of doing it for multiple timesteps?
Old   September 3, 2015, 08:56
Edmund Singer P.E.
singer1812 is on a distinguished road
Untested, but should give your the idea:
!$timestepList = getValue("DATA READER", "Timestep List");
!@timesteps = split(/, /, $timestepList );
! foreach $ts ( @timesteps ) {
!$b=$b+1;
> load timestep=$ts
ADD IN YOUR SESSION FILE RECORDING OF YOUR CHART GENERATION HERE
>chart print, Chart Name = Chart 1, filename = <YOURPATH>/Chart.png, x size = 800, y size = 800, format = png, factor = 0.813406
!rename("<YOURPATH>/Chart.png","<YOURPATH>/$b.png");
singer1812 is offline   Reply With Quote
[OpenFOAM] exporting sample surface data in csv format sihaqqi ParaView 3 July 7, 2013 06:06
[ICEM] Exporting geometry as parasolid format taram ANSYS Meshing & Geometry 0 June 26, 2013 02:38
[Netgen] Error message when exporting to OpenFOAM 1.5 + format almir OpenFOAM Meshing & Mesh Conversion 2 May 25, 2011 04:30
Macro Issue Exporting Chart Data recon9 CFX 1 March 24, 2011 12:46
Exporting GAMBIT files in 'plot 3d' format Jeff FLUENT 0 November 22, 2001 19:52
