Problems considering boundary conditions
Old   January 18, 2007, 07:56
Default Problems considering boundary conditions
Morten Andersen
Hallo all
I have a problem considering the boundary conditions in CFX. I have made an emty wind tunnel with inlet at all the boundaries. I have specified a velocityprofile as shown below
U=alfa*(y/delta)^0.28 alfa=2.99m/s delta=2m
I have used a standard k-epsilon model and specified the turbulent kinetic energy and the turbulence dissipation rate as shown below
k=Uf^2/sqrt(Cmy) with Uf=0.6m/s Cmy=0.09
epsilon=Uf^3/(karman*y) karman=0.41
After the simulation the values of U,k and epsilon at the top and the bottom of the wind tunnel are not equal to the values defined in the boundary conditions before the simulation?
How does CFX uses the defined values at the boundary?
Regards Morten
Old   January 18, 2007, 10:04
Default Re: Problems considering boundary conditions
opaque
Dear Morten,
You said all boundaries are inlets.. You mean no walls no outlets. What is the fluid doing? It cannot be compressed because there are no walls. It cannot get out because there are not outlets..I am sorry, but I did not understand the setup.
In any case, are you looking at conservative or hybrid values?
Opaque..
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 03:18
Some problems on the boundary conditions aweizazuji CFX 4 September 7, 2011 08:47
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 12:55
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
