Home > Forums > CFX
about first layer thickness
Like Tree1Likes
  • 1 Post By Alejandro
Old   January 24, 2007, 06:47
Default about first layer thickness
Eric
Dear Friends,
I am using CFX-mesh to make the mesh. Could you tell me how to decide the first layer thickness?
The fluid in my simulation is compressible.
Thank you in advance.
Eric
Old   January 24, 2007, 10:55
Default Re: about first layer thickness
Alejandro
Hi Eric,
What geometry are you simulating? A way to compute the thickness of the first elements near a wall is to estimate the height of the boundary layer. It depends on the geometry, but for example for airfoils, a good rule of thumb is to approximate the boundarylayer height, as the height of the BL for a flat plate, if your Re number is high enough so that you are in a turbulent regime, then the thickness can be estimated as d=0.14*Re^(-1/7)
So you capture the effects of the viscous sublayer, you should fit at least 15-20 elements within the BL, so a a good guess for the thickness of the first layers would be d/20 (20 extrusion layers, with a small expansion factor).
To decide if your choice is correct, you can also check the y+ values and compare with the ranges advised for the different turbulence models.
I hope it helps. Best regards,
AG.
soheil_r7 likes this.
Old   January 24, 2007, 11:35
John
When you define the inflation layers in cfx-mesh, you can input the Y+ value and the Reynolds number of flow. The CFX-mesgh will automatically generate a first layer which can meet your requirements.
Regards,
Jone
Old   January 24, 2007, 22:58
Eric
Thank you very much. I will try it.
Old   February 4, 2007, 10:29
Eric
Dear Mr.Alejandro Thank you for your answering on the www.cfd-online.com about the thickness of Bounday Layer. Could you tell which book included this formula and the theory? Because I need reference to finish my paper. Thank you in advance.
Best Regards Eric
My e-mail: qiuyifa@hotmail.com
Old   February 5, 2007, 06:08
Alejandro
Hello Eric,
you can find reference to that formula (although the factor listed there is 0.16 instead of 0.14) in "Fluid Mechanics" White, F.
The chapter of interest is "Flow Past Immersed Bodies"
Best Regards, Alejandro.
Thread Tools
Trackbacks are On
SnappyHexMesh - no layer added bejbro OpenFOAM Mesh Utilities 4 October 16, 2014 19:24
Total Thickness of Inflation Layer prikeyma CFX 3 February 12, 2013 04:19
Boundary layer in a pipe Clementhuon OpenFOAM Native Meshers: snappyHexMesh and Others 6 March 12, 2012 13:41
Boundary layer generation problems ivan_cozza OpenFOAM Native Meshers: snappyHexMesh and Others 0 October 6, 2010 13:47
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
