January 25, 2007, 11:12 |
Solver error
what does this error in CFX5Solve mean: was interrupted by signal SEGV (11) I simulate a two-phase flow with flue gas and droplets with CFX10 on a Linux Cluster. Thanks Claudia |
January 25, 2007, 11:15 |
Re: Solver error
Dear Claudia,
That is a segmentation fault, usually due to illegal memory access by the application, in this case the ANSYS CFX solver or cfx5solve script. On this one, you should contact CFX help desk for needed help. Opaque.. PS. Are you sure that all the computing nodes are using the same version of the solver executable? |
January 25, 2007, 11:19 |
Re: Solver error
Hi Opaque,
thanks for reply. I think that all somputing nodes use the same solver executable but I am not really sure. Claudia |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 20:23 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
compile errors of boundary condition "expDirectionMixed" | liying02ts | OpenFOAM Bugs | 2 | February 1, 2010 20:11 |
