some troubles with "USER_GET_GVAR"
Like Tree1Likes
  • 1 Post By opaque
Old   February 10, 2007, 10:09
Default some troubles with "USER_GET_GVAR"
Ardisia
Hi, 1. I'm trying to use Junction box routine to get pressure on some boundary "wallname". But it fails, CALL USER_GET_GVAR('Air Ideal Gas.Pressure','wallname','areaAve', CRESLT,return_Pressure_Value, CZ,DZ,IZ,LZ,RZ), but if I change "Pressure" to be "Density" or "Temperature", then it's OK to get values, why?
2. How can I use USER_GET_GVAR function to get force in x-direction and y-direction seperately?
Thanks for your help in advance.
Old   February 10, 2007, 16:41
Default Re: some troubles with "USER_GET_GVAR"
Joe
1 Different variables are stored at different locations e.g. nodes, integration points etc. This may be the problem.
2 The forces are given to you as a 3 component vector you have to extract the components of interest to you.
Old   February 12, 2007, 09:35
opaque
Dear Ardisia,
The variable pressure is not a phase specific variable; therefore, it should not be prefixed with the fluid name.
Try using
CALL USER_GET_GVAR('Pressure','wallname','areaAve', CRESLT,return_Pressure_Value, CZ,DZ,IZ,LZ,RZ)
instead
This is documented in the USER_GETVAR section, and it should apply for USER_GET_GVAR..
Opaque..
lkm7959 likes this.
Old   February 13, 2007, 23:21
Ardisia
opaque, it works, Use "Pressure" instead of "Air Ideal Gas.Pressure" is OK now!!
Thanks very much....
Ardisia
GAMG solver causes troubles colinB OpenFOAM Running, Solving & CFD 5 June 13, 2013 07:48
Install troubles on fedora yoshimitsuspeed OpenFOAM 1 July 20, 2011 02:49
Interface troubles Samu CFX 2 December 8, 2009 02:38
some video troubles... giosue Siemens 2 February 19, 2003 10:03
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 16:43
